bitcomet help
^ most clients(bitcomet does) allow you to complete your half ported d/l from other clients, just see the clients help file. instruction vary.
its usually the other way around, rite now my taskbar shows about 18 kBps d/l speed, but when see in the task list it’s around 22 kBps, usually what you see directly in the task/peer list is the true figure, on top its average(maybe it’s not continously updated) :frowning:
Yes you can, just open the same torrent file and save it in that same location where you had downloaded the earlier file (with the same name)
aaah, heres a superb solution to get ammmzingg speeds on bitcomet…
install bitcomet 0.59 (YES),
and then get a software called bitcomet accelerator from softpedia.com, its a freeware.
man has it increased my speeds or wht…
its really cool, and it works…for a change…i’d recommend using the bitcomet accelerator.
get it here:http://www.softpedia.com/get/Internet/File-Sharing/BitComet-Accelerator.shtml
cowax if u go to the bitcomet forum http://www.p2pforums.com/viewtopic.php?t=16853 its clearly stated there is no accelerator which works
hmmm. wierd, cuz tht stupid thing did actually work for me…yeah, n it is a spyware, cuz even my nod32 detected newdot net spyware, and eleminated it, it still works with the spyware being deleted.
