Re: How to block webSites without any Softwares
I really am not finding the hosts file…
i guess its better for noobs to use firefox with adblock plus and noscript
DNSkong might be the only way to stop sites like dblclick..
how else to stop a4578.dblcick.com ?..that number is semmingly random at times.
nice stuff thats helpful..good stuff
Wow, thank you for your helping hand in fixing my problem! Truly.
well gud one
i have heard long back
I tried to block using this method, but no luck. Any suggestions?
I did try to look at the suggestion posted by Hunter on 9/23/07, but when I opened it, it was not clear enough to read..
Simple and effective. Regarding pop-ups how do I determine its url so it can be manually blocked?
U mean u opened the attachment but it wasnt clear?? Its very clear for me, each and every alphabet.
Does it appear now?
It work very well for me. If it not work, maybe you did not save.
Now how to block porn sites with one keyword. And is there a list somewhere where I can see what sites are dangerous for my, your computer?
Thanks a lot.
Really a good idea to block a website without having any software for it…
Thanks 4 d idea..
Excellent…keep it up…
Thanking u…
Vivek Mishra😄
Great stuff..
Thanks for the info.
Nic einfo, thanks!
You can also use Opendns service or may be ipsec too
Hi, I’m new to this forum:D and I tried to do this method of blocking a website but it didnt work I took a look at the screeshot and thats the exact same thing that I did.
Are there any other methods of blocking a site??
Thanks
Read already. Thanks anyway.
hey, im also new, and ive tried everything sudgested. I really want to get rid of the bearshare website but its just not working. Any sudjestions what to do?
Yeeah man, I thought some kind of binary wrapper is posted here that blocks connection.
~LT
so how to unblock it once blocked.
i am not getting the entry i enterd, but it blocks the site i gave
