Mandriva 2008.1 Spring Edition : Breath Of Fresh Air
Thanks :slight_smile: @ Mods please clear that long list of Linkbacks :slight_smile:
Excellent work on the review..Man you have put in some real hard-work! Great work :slight_smile:
Btw, its Metisse and not Metissa :wink:
^^Hey thanks :slight_smile: Fixed the spell mistake :stuck_out_tongue:
I missed an important point :@, that Mandriva comes with Full EEE PC support and you get Online Support and help especially for EEE PC for Power Pack edition :expressionless:
Gr8 review darky!
Some suggestions:
  1. Please include the download links (for downloading the distro) in the review too.
  2. Please avoid using words like ā€œI was shocked to seeā€. Instead u can use ā€œI was pleased to seeā€.
^^Thanks .. Added the d/l link.. and I used shocked because it can be used in both sense but please can be used in only one sense.. But point noted sir.. will use much better words next time :slight_smile:
Installed Mandriva on more than 30 computers today :slight_smile: and 2 laptops.. Wow it configured all the ATI and nvidia drivers and Compiz out of the box.. Every one was stunned to see the eye candy :drool2:
Where was this? In the school your mom works at?
^In my school and in the College where my Mom is Principal.. :stuck_out_tongue:
Nice man I’m gonna try this..
While the review itself is neat (and Darky repped) here’s my rant about Mandriva and Fedora 9 in favour of Ubuntu :stuck_out_tongue:
See http://www.techenclave.com/831091-post79.html
Nice Review :slight_smile:
Installed in my lappy everyday…the dealbreaker was Wifi (Broadcom) was not installed as it asked for ndiswrapper. Its a deal breaker. I know broadcom is at fault for nt having proper linux driver but still w/o wifi whats the use :frowning:
^^Install the BCM43XX driver as stated here Mandriva 2008.1 Spring Edition : Breath Of Fresh Air - TechEnclave
excellent work..:slight_smile:
installed it in my laptop and running great…
just speakers echoing internal sounds and headphones buzzing continuously.. :frowning:
^^try to play around with Kmix Master Audio Center or Pulse Audio to fix the Echoing or Buzzing.. You can access those tools from Main Menu → Sound , if you are using Kick Off then Main Menu ->Application → Sound :slight_smile:
What model do you have? For my tablet, Fedora 9 worked a bit better with the built-in kernel driver called ā€œb43ā€, although you still have to download the firmware and type a few commands to get it set up, but much less work.
The b43 loading error in dmesg output itself points you to a URL with the steps :smiley:
yes would try that…
actually been pretty busy for a few days and hence didnt get much time to try fix the issue..
thanks for the suggestion :slight_smile:
Guys digg the post here.. Some one dugged it again but this one is more popular than earlier on :stuck_out_tongue:
Digg - Mandriva 2008.1 Spring Edition : Breath Of Fresh Air
Hey Dark Star,
One quick question .. can i set this up on RAID 0(nVidia 680I Sli board) with dual boot setup(Windows XP/ Windows Vista)??
If so, Please direct to me to a link which tells me how to add nvidia storage media drivers for RAID 0? or else will it work automatically..?
I have it downloaded already.. waiting for your inputs before proceeding further…
Cheers,
Jay
Since I don’t have Raid setup I was unable to answer. So I confirmed this with my friends .. It should work automatically.Set up the RAID in the NVIDIA utility, then run the Mandriva installer, choose ā€˜manual partitioning’, and see if it detects the array correctly.
