info on noise???
Yep, the PSU fully obstructs one top-back fan and if you install a DVD/CD Drive then another one top-front fan gets blocked. But still there is some space for air to go out through these blocked two fans. So when I checked the air flow, the middle two fans blow a lot of air. However the two blocked fans also blow out some air. I could feel the warm air blowing out of all these fans…
The CPU temp is cool at 32-35 idle and 48-52 full load (I am using Thermalright Ultra 120 Extreme, Room temperature is 30). The left side fan was exhaust fan, I made it reverse to blow air inside the cabby and the GPU temperature reduced from 65 to 52 (which is the same temp I get when I kepp my cabby open). The temp of Northbridge and Southbridge however increased due to this
Well I am kinda immune to external noises. I can hardly notice when an aeroplane flies over my building (staying near the airport) or my neighbor’s 1.5 ton AC growling all the time!!!
The only noise that is noticable when no plane flies or AC is off is that of the side and back LED fans (whose speed can be controlled and hence noise can be reduced if you wanna watch a nice movie). The top 4 fans hardly contribute to the noise…
Looks pretty good indeed..
any idea whether its available without the psu?? I may just need the cabby..
Yep, u can get it without the PSU (but it depends on the dealer). The Dealer may reduce the price by 300-500 bucks (depends on ur negotiating skill & luck )
Only ‘Yuck’??
I would have loved a ‘WTF!!’ instead.
Totally out of this world stuff.- like the Wraiths from SG.
j/k.:cool2:
gonna be my next cabby..:)!
Is the cabby big enuf to house a 8800GTX? and does it have enough fan slots to keep a 6850 cool?
Hey all of u Enthusiasts just check out the Viper 2 the new bro of Viper which our friend has got.Its even more Awesome than earlier one.
ANY WAY i can get this cabby in KOLHAPUR ?
Chii Umax Has Shabby Quality
