i also have read 1604 is a problem when its not in D.F.U Mode, but i’m sure, i put in dfu mode, a black screen comes at first, then after 2 minutes it turns to white, apple logo or itunes logo come if its entered to RECOVERY mode right?
Not sure if this would help. But give this a shot.
whats it? u mean i can do jailbreaking without restoring the firmware?
you mean 2.02, the latest version?
now with itunes 7.5 i’ve installed 1.1.4 firmware and then installed custom made firmware 2.O using winpawn, but after install, the phone showed some neubootloader or some thing like that came and asked to wait for two minutes, after that it showed bootloader failed and phone is restarting.. It restarted , then i switched off the phone to insert the sim, but when i switched it on after inserting the sim, it was not booting up and showing the itunes logo again.. Can anyone pls help me out
Dude get some professional help if u r struggling with it!
i have an iphone (1st gen) unlocked using anysim 1.1 .. the current FW version is 1.0.1.. how do i get it to the latest firmware. do i need to revirginize it n use winpwn? can anyone explain how to get this done n simple steps? Also, will i then be able to use the app store apps (legit/broken)..?
