Guys i need to buy a 2.0 speakers.
The reason: i simply don’t have space for a subwoofer. plus the cable mess and the most important of em alll heavy base can be really disturbing for people around you after 12 in the night
Which of these speaker is better…
- Creative Gigaworks T20
- Klipsh Promedia Ultra 2.0
I had seen one of a Klipsch in the show off section. I guess its available here then. but what about the creative speakers. are they available here??
I’m leaning towards Klipsch cause most of the brand value (at least i think it has some ). Please help guys…my budget is around 8k. Are there any shops in chennai where i can go and listen to them before buying???
Thanks GreenHorn - 2.0 is due to lack of space…and my mom hates booming bass…
The wharfedale speakers - can they be directly connected to the comp??? If they need an amp. then they’d be totally out of my budget…
Plus space is real issue. i really want to avoid big bulky speakers…unless of course their performance is extremely good…and I’m more into soul, r and b, and malayalam songs…though i do listen to metal every once in a while…so bass is not really an issue…
Edit: can someone tell me what the price of these wharfedale is in india???
And bout unbranded stuff…but i have no technical knowledge whatsoever…so i think i’d rather stick with something branded…unless i have no other option…
Er, oops.. they need an amp… thought they were active… sowwie for getting your hopes up
a good stereo setup is ALWAYS bulkier than its equivalent 2.1 and a good refined 2.1 like the altec lansing MX 5021 shouldnt sound boomy at all.ever heard the altec lansings? at 8k, they’re real fine , and they’re cheapest in madras:D
I know they sound good…but its the size…
My room is about a 100 sq.ft with a full size bed a steel almirah…:S
There is hardly enough space to sit in front of the computer…
And a big woofer is a big no no…
The speakers even if they are big can be mounted on the wall…the same cant be done with the woofer, can I??
Edit: so please recommend me a 2.0 system for under 8k (now thats te max!!!)
The Mx 5021 is a 2.1 speaker system with a subwoofer…It gives you more bass…the promedia ultra 2.0 doesn’t have a sub…so it lacks bass but saves space…
