ati ccc query / problem
i was using ati ccc 6.9 for quite a long time. upgraded to 6.11 some 4-5 days back. while installing i got the usual windows popup thing about the drivers if i want to continue anyway. dont remember this coming before in 6.9 or earlier so wanted to know if this is happening to others also.
2ndly after finishing installing the drivers etc. in the device manager its showing an exclamation yellow sign/circle next to ati t200 unified avstream driver meaning its not installed properly. used to install perfectly with 6.9.
i install 6.12 still both these same problems are there. although the games & everything work perfectly without any problems, was just curious y these 2 things were happening. is it just me or its the case with every1 cause it was perfect with 6.9.
also another thing thats happening with 6.11 & 6.12 which dint happen with 6.9 is that i cant change the fsaa & anisotropy levels from techpowerup ati tray tools. if any1 else has techpowerup ati tray tools please check & let me know.
the card i am using is x1900xt.
