Camera repair
I had bought a Sony digi cam from Alfa 2 years back. I didn’t use it this summer and when now it doesn’t start. I tried with new batteries, rechargeable cells etc. and it still doesn’t start. Anyone know where i can get this problem fixed?
Recently, when I took my 4 year old Nikon Coolpix 5700 (which stopped working) to the camera repair shop, they examined it and said the CCD and a strip cable are to be replaced. I was asked whether I had kept it unused for long which was true. I was also told that proximity to sea also accelerates failure. But I had always kept it in an airtight transparent jar and the lens is still free from fungus. Their charge is 4.5K and I am wondering whether it is worth it!
You can visit any Sony service centre and get it repaired.
i think we need to keep some pouches of silica gel along with the camera to absorb moisture.
OT: same thing happens to phones (with caller ids) - the strip cables invariably stop functioning when the phones are kept unused for a long time.
Sorry, I forgot to mention it. Over the years I have always been doing it and change it when the colour changes. And that is how I prevent fungus. (also the air tight jar)
Btw, I happened to read that even too much of silica gel is harmful and that it dries out the lubricants. (I do doubt whether that was what happened to mine)
From where can i buy Silica Gel pouches and how much does it cost?
Available with any Laboratory supply store and is cheap.
^^^ you mean chemist shops ??? sorry i dont know what is laboratory supply store ::flushed_face::
Edit:
Those stores which supply to labs of schools/colleges.
Sorry for posting absentmindedly.
Google is your friend…
silica gel loc: New Delhi, Delhi - Local
Get the silica gel with the indicator dye, this changes colours when saturated with moisture and gets back to original colour when heated and ready for reuse , I use a hair dryer to heat and regenerate silica gel.
