this must be asked many times… i just want to reconfirm can i connect my cellphone and lappy to my pc net conn by a simple wifi card…
also which wifi card to buy…
i might also need to listen music and watch movies residing on my pc…
regards
neo
regards
neo
yes you can..get a wifi card.
If you have vista, then go to setup a network connection, adhoc network, and select internet connection sharing later on when the wizard asks..
simple..
It would be better to get a cheap wifi router for 1800 soemthing and use it..use the desktop using wired lan..
ok will get a wifi card… any good brand and price range…
**also what about running movie and music over air just with the wifi card… **can i do that… router would be not much use to me but stilll i can give a try..
which one would be better for a router below say 2k…
