This is probably a pretty basic question but…
one of my laptops is messed up and needs to be formatted and before I do it I want to get off the files, word documents and stuff. I can only get to the screen when it comes up saying:
\windowszsystem32zconfig\system missing or corrupt
i only have an ethernet cable but I’m going to get a USB cable so I can connect them. I know for a ethernet cable i need to configure all that IP stuff and I cant even get onto windows on the bust computer so I was wondering if it will even work if I use a usb cable?
A guy told me once the drive isnt physically broken I can access the files but when I connect the ethernet nothing happens since I cant configure it.
Any one know if the USB cable will do the trick? I just dont really see how I can get files off it if windows wont even load up on it.
What do you think?
Dave
