Can any one provide opinion on below mentioned cooling kits. Are they worth the price. I am desperately in need of a cooling solution for my XFX GeForce 6800 GT. Which one would be best. The last item is a liquid cooling kit for both CPU and VGA. Any other suggestions?
Arctic NV5 VGA Silencer
KingWin KWVC 3 VGA Cooler ( http://www.cluboverclocker.com/reviews/cooling_devices/Kingwin_KWVC-3 )
Kingwin AWC-1 Arctic Liquid Cooler ( http://www.xpcgear.com/awc1cooler.html )
Nikhil
June 16, 2005, 7:01pm
2
Link please… please give me a link… I am too lazy to search for it myself…
[b][i]Nikhil posted 9.6 minutes later:
[/i][/b] http://www.google.co.in/search?sourceid=navclient&ie=UTF-8&rls=GGLD,GGLD:2005-16,GGLD:en&q=Kingwin+AWC-1+Arctic+Liquid+Cooler This is for the liquid cooling…
http://www.google.co.in/search?sourceid=navclient&ie=UTF-8&rls=GGLD,GGLD:2005-16,GGLD:en&q=KingWin+KWVC+3+VGA+Cooler This is for the other cooler.
I am personally not in favour of the KWVC 3 cooler. It may be very quite but it will not perform up to the level of an NV Silencer 5.
Just reading up on the water cooling part now…
But keep in mind that with the exception of the NV Silncer, none of the others are available in India…
[b][i]Nikhil posted 2.12 minutes later:
[/i][/b]I am not in favour of the cooling because it takes up waaaay too much space in your cabinet. And it says fanless but for optimal cooling, you need 3 fans as shown in this review… http://www.cluboverclocker.com/reviews/cooling_devices/Kingwin_KWVC-3/page3.htm
[b][i]Nikhil posted 1.25 minutes later:
[/i][/b]And that water cooling is also not the best. You may as well go for a better Dangerden A64 cooling solution…
I am going to get the cooler from abroad
But i have to keep the budget in view. Danger den are way too costly. Also my priority is the Graphics card. its getting too hot. If i am able to get a water cooling kit for 100 to 120$ then i can go for it.
