But the cooler itself is 150mm tall. And i have a 35mm fan on the side panel so i doubt it would fit…
Would it touch the side panel in the ATX case? And should i move the fan to the outside? Or will it fit?
I am thinking of rotating my side panel by 180 so that the above side panel fan would blow over the RAM and also give cool air to the fan of the Cooler. And the below fan would blow directly over the 9600GT fan. Dat’s a good idea as far as i think. :cool2:
BTW, how much are ur improvements after using the Sunbeam on ur 5200+. Have u overclocked it? What were ur temps with stock cooler and now?
While installation did u had to push the side levers on the Cooler over the processor bracket to fit in? I read in one of the reviews that the Cooler doesn’t fit a AM2 board et all and they had to push it very hard(which could damage the processor i believe or the Cooler Mount) for it to fit in.
And it seems as u told, i’ll have to remove the PSU before installation which is a pain in the a**.
Any Pics of ur rig mate that u can show me, i would be thankful
