Creative Zen Vision:M (30GB) - Review
Hello people!
Finally managed to lay my hands on the Creative Zen Vison:M..
This is my first ever review, so pleeeeease bear with me..
A good friend bought it for me from the US of A for $320 (approx Rs.14600).
Sorry, i dont have a digi-cam with me right now, so i’ll be posting to links for pix from other sites..
Thats what you get from the box… great packaging i might add..
http://www.anythingbutipod.com/archives/images/zen-vision-m/creative-vision-m-main.jpg
Supplied are
The Vision:M
2 cds (one installation and another Yahoo! Music thingy which i havnt figured out what to use for)
A dock for charging, transfer, A/V output.
A pouch (nice and smooth, but white, so it’ll get dirty if my Vision doesnt)
A pair of Creative Headphones. (great sound quality.. i’d say equal to the iPods headphones..)
USB Cable (for data transfer and charging via USB)
AC Adaptor and an ‘American’ plug..
Heres the dock.
http://www.everythingusb.com/images/list/creativevisiondock.jpg
Heres how it looks
http://common.ziffdavisinternet.com/util_get_image/12/0,1425,i=125454,00.jpg
FEATURES (Pros)
Controls:
Vertical touchpad. 4 buttons-> Shortcut, Play/pause, Back, Options
By brushing up and down on the touch pad, it allows you to scroll through tracks and menu items. By tapping on the center of the touch pad, it selects the current item.
The buttons have audible clicks, so you know when you’ve pressed it.
Hold/on/off slide on top.
Easy navigation .. (i got used to it in less than an hour..)
Shortcut key helps you out.
http://www.asia.cnet.com/i/r/2005/pav/39097200/b005.jpg
The small buttons on either side of the touchpad are VERY helpful in fast-forwarding, and moving along the playlist,etc..
Screen:
Excellent. more than 240K colours.. compare that to the 65K colours iPod.
Though i hear this does not make much of a difference on a 2.5" screen.
Though a comparison of vid/pics on an iPod and Vision, the Vision looks much better..
http://www.everythingusb.com/images/list/creativevisionsealion.jpg
http://www.everythingusb.com/images/list/creativevisionkingkong.jpg
http://www.everythingusb.com/images/list/creativevisiondwarfs.jpg
The Zen Vision:M supports lots of formats.
Audio: MP3, WMA, WAV (and ogg too i think..havnt chked that out yet..)
Video: AVI, DivX, MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, WMV, XviD
30 frames per second.
The video playback and quality(contrast) is stunning.
Now you can just dump movies downloaded off torrents or p2p networks into your player and watch 'em..
If any video needs to be converted (because of the crappy codecs they were intially encoded in..) Zen Vision Media takes care of that for you for which 3 converting options are provided.
Pictures:
Supports Jpeg… other formats will be automatically converted then stores.
Slideshow is good.
But manually browsing thro the pictures is a bit slower compared to the iPod.
Sound:
Great. EQ, Bass Boost, Smart Volume.
Playback:
Setting a playlist will take sometime for you to et used to, but its cool..
There also a “DJ” option, where you can play best rated songs (you can rate them out of 5 stars), or least heard songs,etc.
Bookmark feature may be useful for long audiobooks.
Battery:
The rated battery time for the Zen Vision:M is 14 hours of audio or 4 hours of video playback.
(iPod video playback is for 2 hours only.)
The AC adapter takes 2.5 hours to charge it completely, where as the USB adapter plugged into your computer will take 6.5 hours to charge completely.
Removable Drive feature. You can create a separate drive-> 512mb, 1,1.5,4,8,16gig for transfer of data like a USB drive.
FM tuner and FM recorder.
With auto-preset feature, i.e, it’ll search and store all available stations.
Voice recording: only in the IMA ADPCM 16kHz mono WAV format
Customizable wallpapers.
Themes.
Albumart display is cool.
Sync Outlook Contacts.
Calender, alarm, date/time, organizer.
ZENCast (never used it tho..)
Password protection: You can protect pix and vids with Passwords… (quite useful eh :wink: )
PROS: All the above ^^
CONS:
Now i havnt used the iPod a lot (which is the standard for all comparisons i believe), but here are some comparisons:
http://www.everythingusb.com/images/list/creativevisionsize.jpg
The Creative loses out on size and weight..
Its bulkier and heavier than the iPod and almost twice its thickness (and weight)
These are the downsides i could find on the outside.
A major down fall of the Zen Vision:M is that it is not UMS (Universal Mass Storage) compliant. You cannot simply plug and play then drag and drop files to the player on any operating system without additional installation of drivers.
Once can transfer data to it by means of the “Removable Drive” option, but data thus transferred cannot be used directly by the player, for eg, if you transfer mp3s from a friend’s pc (which obviously will not have Media Explorer) as data, you wont be able to listen to it on your player until its transferred by/via Media Explorer.
I’m praying for future firmware which will make it UMS if possible..
The buttons are located slightly along the outer edge.
Some may not like the buttons (for their nature/sound)
Carrying the dongle around.
Non-removable battery.
No games… (but if i wanted games i’d rather buy a PSP)
If Creative manages to reduce the thickness and weight a bit, they’d definitely kill the iPod.
Go for The Creative Zen Vision:M if you dont mind it being a bit thick, but need to use various video formats and stuff.
Go for the ipod if you want something sleek.
EDIT: I’ve just read some more about the Vision:M. Seems you can transfer media via Windows Media Player, so though it aint UMS, you can still transfer media (MP3s, Movies) from your friends PC and play them by using WMP to transfer them !!
EDIT Number 2:
Theres something i do not understand.
According to the other reviews i’ve read, the Vision:M is NOT UMS (Universal Mass Storage) compliant.
According to the manual, you can “Sync” media(=mp3s, vids, pix) onto the player via WMP10.
Now, when i connected it to my college’s IBM pc with WMP10, it didnt show anything.
BUT, when i connected it to a friend’s PC (without Zen Media Explorer), it was recognized as an “MTP” (Media Transfer Protocol), and i’m able to copy media not only via WMP10, but ALSO as an external device(i.e., using “My Computer”!!!
I understand that UMS is “Universal” whereas MTP is for Microsoft(Windows XP with Service Pack 2)… so i think thats good enough, since all my friends use WInXP SP2..
BTW my player froze twice within 12 hours yesterday. i had to reset it by inserting a pin into the Reset hole at the bottom.
Then a “Rebuilding” process took place for like 90 seconds, and the setting returned to how it was the last time it was Shut Down properly.
Another review i recommend you read if you’re interested in buying the Vision:M is
http://reviews.cnet.com/Creative_Zen...1&cval=1711841
Eat your hearts out ipood fans (no offence) :P. Nice review Vince, reps added and the thread rated.
nice review, some larger pics would have helped
Nice bu Vince…COngratulations…Enjoy time with your new puppy :smiley:
I just discovered This Site :stuck_out_tongue:
Repped.
Nice review.
Nice review and Awesome player!! Me wanty :stuck_out_tongue:
This is supposed to prevent piracy :stuck_out_tongue:
Thanks guys..
@BladeRunner: I didnt exactly bash the i’poo’d :stuck_out_tongue:
@bottle: i still havnt got my digicam, so sorry i couldnt post any personal pix, maybe by next week, i’ll be able to do so.
@Superczar: Oh Yeah!!!
@Nikhil: Heh, yea right :stuck_out_tongue:
:frowning: its heavy, i put it in my shirt’s front pocket, its pulling me down.. :frowning:
have to put it in my trouser pocket only.. :frowning:
Pretty cool review. Good work. :blush:
@goldenfrag: ah, yea, that was one of the sites i used to make a decision on the Creative Zen Vision:m…
Nice,cool and detailed Review pal:) Repped ya:D
Firstly must say nice review.
Thread Rated and Repped :slight_smile:
Can you elaborate a bit more on this please
1.> If any video needs to be converted (because of the crappy codecs they were intially encoded in..) Zen Vision Media takes care of that for you for which 3 converting options are provided.
2.> Removable Drive feature. You can create a separate drive-> 512mb, 1,1.5,4,8,16gig for transfer of data like a USB drive.
I didnt get you here can u tell me how this 512/1/1.5 etc… :thinking:
3.> Once can transfer data to it by means of the “Removable Drive” option, but data thus transferred cannot be used directly by the player, for eg, if you transfer mp3s from a friend’s pc (which obviously will not have Media Explorer) as data, you wont be able to listen to it on your player until its transferred by/via Media Explorer.
Some more queries
  • Can i connect the A/V out to a TV and watch and listen to videos and mp3.
  • No ways can i add data on this player without the software driver installed na , after the software installed can i transfer any file.
The Creative shud have supported the UMS feature then it wud have killed ipod.
Still must say the loads of features that this support are really much much better than what ipod offers.
Thanks, and i hope this helps anyone looking for info..
Sure!!!
Yes. But the A/V cable is not supplied. I only have an old such cable. when i connect it to my tv via the dock, a message is displayed on the player that “Syncronizing with A/V output” or something, but nothing is being displayed on the TV,… i’ll have to get a new cable and test it out..
Oh, and thanks for asking me this, coz as i was hunting for that cable, i came across an old adapter A/C wire which i can use for charging… THanks!
I’ve transferred a number of mpg, avi, divx, wmv files onto it with no conversion needed.
But i did have to convert a few wmv files using Zen Vision Media Explorer, for my player to accept those files. i think that is because they were encoded using a different wmv bitrate or something..
There is a feature called Removable Drive.
Here, you can format a part of the drive into either 512mb, 1 gig, 1.5gig, 4gig, 8gig or 16gig. Or you can disable it.
When you access this feature, set the capacity, and connect to a PC, it shows up as a Removable Drive (like a USB drive ..)
The media (mp3s vidz, etc) on the player cannot be accessed by this feature.
Think of it as a separate partition.
Think of “Removable Drive” as a separate partition.
As i’ve added in my “EDIT”, you can use Windows Media Player to sync media to the player.
I’ve tried it and it works WITHOUT accessing Zen Vision Media Explorer.
I’ll try to test it on my friend’s PC (which doesnt have Zen Vision Media Explorer, just to be sure) and post the results (hopefully tomorrow).
Thanks a lot Vince for clarifying my doubts .
Is that A/V Cable available here in India easily if yes for ???
Is this toy available in India as i am so much tempted to get my hands on this .
Lets see how things shape up.
In May i am planning to get either this or the PSP.
If i luckily get a PSP Ver 2.0 or 1.5 then only will i get it :wink:
Or will get this instead.
Er.. no idea..
Mine was an old one.. dunno where/how i got it..
I remember buying another one recently, and a friend borrowed it.. i’ll ask him to return it..
Dude, i emailed Creative’s dealer here in Chennai a few days before my friend bought it in the U.S..
Guess how much the Creative Zen Vision:M is here?
Rs.28,000.
Thats DOUBLE the price for which its available in the U.S.
Crazy eh?
Great going Vince - the best part of your review and subsequent posts is the way you are going inside out in knowing all the features supported be your Zen and trying them out first hand, and the best part is you are sharing your adventure with us.
If we ever go for Zen Vision - one of the prominent factors for that decision would be your review :wink: Keep up the good work mate :slight_smile:
OMG thats damn high.
Will check out here at alfa lets see what they quote.
If this is gonna be so damn high then psp will be my choice.
yup..thats too high a price…any idea how the prices in the gray mkts are like?
OT: Any idea how mch is the PSP retailing for
PSP is close to 11~13K here.
But its very hard to find Version 2.0 Firmware based PSP’s
[u know what 2.0 is capable of] :wink:
'course :stuck_out_tongue:
you have a PSP..isn’t it
I Hope the Mods can edit the folloing EDIT to the main article (i’m sorry if i’m irritating anyone by this, but i’m STILL exploring what i can do with my baby…er.. Vision:M)
EDIT Number 2:
Now, when i connected it to my college’s IBM pc with WMP10, it didnt show anything. :frowning:
BUT, when i connected it to a friend’s PC (without Zen Media Explorer), it was recognized as an “MTP” (Media Transfer Protocol), and i’m able to copy media not only via WMP10, but ALSO as an external device(i.e., using “My Computer”!!! :smiley:
http://reviews.cnet.com/Creative_Zen_Vision_M_30GB_black/4864-6490_7-31632696.html?ctype=msgid&messageSiteID=7&messageID=1711841&cval=1711841
@Dipdude: Thank you! BTW, my adventure with it is still continuing!!
@Quadmaster: I’m still trying to find another A/V cable. will post here once i get to test it.
@Superczar: i couldnt find the Vision:M in the grey market ..
