The new big dog of 120mm fans has arrived! After many months of waiting, TFB1212GHE is finally here. A step up from the already extreme 190 CFM FFB1212EHE and the first 120mm to break the 200 CFM barrier, this bad boy plops down a solid 220 CFM at 65 dB using Delta’s new TFB fin design. What surprised us most was this part weighs 70 grams less than FFB1212EHE. A pretested sample concludes airflow output is genuine with high self-inertia and it seems most of what makes noise on this part is the airflow itself.
I want this!!! And will it run off a normal PSU??? I can get this… I WANT THIS… MY uncle is in the US right now…
And can I just run it off the main PSU like a normal fan??? Plase reply soon
[b][i]Nikhil posted 6.52 minutes later:
[/i][/b]And what connector type should I choose??? 3 pin Molex or 3+4 pin molex??? What is the difference??? and what abt the expandable sleeve option???
Yeah it should work. Eats 29W. So u cant run it off mobo headers but it’ll run directly off the psu rail. Thats pretty old actually, ntn new. Been there at sidewinder since like over a year.
I look up to Sunny, for making his water cooling kit ! Man you gotta have balls to let water run down your 60k plus hardware knowing that even a drop could blow your system ! Great job Sunny !
the last time i removed everything and put it back, i didnt even care to check for leaks before running the system…thats how much confidence i’m having nor i use those clamps on any of the pipes…
