e4300 + p5n-e sli OC Help
@200
ive gone thru the guide.. ive learnt how to OC from the guide
so 2.4 is the best one can do on stock?
ppl
since putting in my ( smps cm 600w extreme ).. my hdd is being detected as st3320..AS 3.AAK
3.AAk is being shown recently
wat does it mean?
srry.. shud have googled it b4 posting..
its the firmware version of my hdd
you can go further depends on your temps, make sure ur on the latest bios. to flash it use the bios updater application you got in the cd. have a look at the temps from core temp .95 . see if you can push it further. anything under 65 below load is good. i say get a tl ex 120 and take it to 3 ghz
