FS: Soundblaster Audigy 4 Pro
**Selling my Creative Soundblaster Audigy 4 Pro . Got it from U.S and now 6 months after I have got it, I realise that i dont use most of the features of “pro” part of it. You can convert your PC into a complete media center using this soundcard and you can control the song tracks, movies, pictures ****etc **on the harddisk with the remote provided. Selling it for 8k. If willing, i will give away my 4.1 speakers for 1k to bangalore buyers (obviously cant ship the speakers). You can check more about the soundcard here and more about speakers here . The speakers will not be sold individually
SPECIFICATIONS
Audigy 4 Pro Processor
  • Advanced hardware accelerated digital effects processing
    • 32-bit digital processing, which maintains a theoretical 192 dB of dynamic range
    • Patented 8-point interpolation that reduces distortion to inaudible levels
    • 64-voice hardware wavetable synthesizer
    • Professional quality digital mixing and equalization
      High Definition Audio Quality for Playback and Recording
  • Playback of 64 audio channels, each at an arbitrary sample rate
    • 24-bit Analog-to-Digital conversion of analog inputs at 96 kHz sample rate
    • 24-bit Digital-to-Analog conversion of digital sources at 96 kHz to analog 7.1 speaker output
    • 24-bit Digital-to-Analog conversion of stereo digital sources at 192 kHz to stereo output
    • 16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96 kHz.
  • Supports Sony/Philips Digital Interface (SPDIF) format of up to 24-bit/96 kHz quality. Selectable sampling rate of 44.1, 48 or 96 kHz
    • Low latency multitrack recording with ASIO 2.0 support at 16-bit, 48 kHz and 24-bit, 96 kHz resolution.
*(Latency performance may vary based on system configuration)
FireWire® (IEEE® 1394) Connectivity
  • Compliant with IEEE 1394a specification
    • Supports data rates of 100, 200, and 400 Mbps
    • Supports up to 63 FireWire (IEEE 1394) compatible devices in a daisy-chain configuration
    • Supplies up to 3 Watts to FireWire (IEEE 1394) compatible devices
      Sound Blaster Audigy 4 Pro On-Board Connectors
  • Line level out (Front / Side / Rear / Center / Subwoofer)
    • Digital CD Audio in
    • Aux Audio in
    • AD_Link 1 and AD_Link 2 connectors to connect with external I/O hub.
    • Power connector
      Sound Blaster Audigy 4 Pro External I/O Hub Front / Rear Panel Connectors
  • Headphone Out (1/4" Stereo Jack)
    • Line In 1 (1/4" Stereo Jack , shared with Mic In with Gain Control)
    • Line In 2 (1/4" Stereo Jack)
    • Line In 3 (2x RCA Jack)
    • Optical SPDIF In/Out
    • Coaxial SPDIF In/Out
    • Digital Out for 5.1 support (6-channel SPDIF Output to Creative digital speakers)
    • 2x FireWire® (IEEE® 1394) ports
    • MIDI In / Out
    • Infra-red Receiver to communicate with Remote Control
    • AD_Link 1 and AD_Link 2 connectors to connect with Audigy 4 Pro
      Audio Performance:
Signal-to-Noise Ratio (AES17, A-Weighted)
Output Voltage @ 2Vrms
Stereo Output 113dB
Front and Rear Channels 113dB
Center, Subwoofer and Side Channels 113dB
Total Harmonic Distortion + Noise at 1kHz (AES17) = 0.003% (2V Rated Output) Frequency Response +/-3dB: 10Hz to 46kHz
Works with the Following Standards:
  • Windows® XP and 2K
    • Sound Blaster MIDI and General MIDI
    • Plug and Play
    • Sound Blaster PCI
    • EAX, EAX ADVANCED HD
    • Microsoft® DirectSound® , DirectSound 3D & derivatives
    • OpenALâ„¢
    • PCI 2.3 compliant
    • AC '97
    • Dolby Digital
    • Dolby Digital EX
    • DTS Digital Surround®
    • DTS-ES Surroundâ„¢
    • Meridian Lossless Packing
    • ASIO 2.0
    • SoundFont 2.1
    • DVD-Audio
    • Windows Media® Audio 9
Hi!
am interested in picking this up. where in blore do u stay? the sound card has no issues right and it comes with all the original demo disks and accessories?
No issues at all. Got all original accessories. I have pmed u
Bumpety Bump!!!
Bump and ten chars
Bumpy!!!
