It would really depend on what the primary function of the cable is. You can always buy a dvi/hdmi adapter or an hdmi/dvi adapter after if you need. You are likely to get a better quality picture without an adapter, so I would suggest getting whatever you have a primary need for.
Cables’re expensive but then u need not keep on unplugging ang replugging ur existing HDMI cable from the device it is conected to like the PS3 or the DVD player;
So I was thinking whether I could land some cheap ones at Lamignton road:)
If I dnt get cheap there then only option is to order online:cool2: but would these cables attract any customs or something like tat:S
Found DealExtreme it provides free international shipping:)
So the total cost would come around 13-14$,so would such a small cost attract customs:S if yes,then by how much shud it by undervalued say to abt 10$*(noob to international buyin)*
