Help choose Digital camera with 28mm lens
Hi,
looking for a good and simpple to use Digital camera, around 6-7 MP, must have 28mm lens and not the standard 35-38.
price is under 20k, should be slim if possible
yes…i did go through 4 pages out here and then i posted.
Vivek
Fuji FinePix E510 Digital Camera, Panasonic Lumix DMC-LX2 Digital Camera, are some of the ones. A slim with a wide angle is hard to find. I would recommend you to go for a digicam according to your liking and then get a separate wide angled lens as an attachment.
if by any chance u din’t know about these models u might wanna have a look at these:
  1. panasonic lumix dmc tz3 ( 7.2mp, 10x optical zoom, 3" lcd,28mm lens)..the downsides are its low internal memory of abt 12mb and lack of usb 2.0 support. no idea about prices here but it retails arnd 300$ in intrl markets.
  2. sony cybershot dsc t100 ( 8mp, 5x opt zoom, 3" lcd, hdtv out but unfortunately its equiv to 35mm lens) superb compact cam i’d say.
Spend 2-3k more and get a Nikon D40 with an 18-55 lens in grey. Best bang for the buck.
the Panasonic looks nice…is it available in Mumbai?
The Nikon D40 looks too complicated…i need to strike a balance where my Kids can point and shoot and i can get my wide angle with simplicity!
Vivek … +1 to the Nikon D40…a pal got it last week and the pix it takes is amazing…it has a automatic mode as well…so it doubles up as a PnS as well…
The panasonic one is available in jjmehta(16k without any card) and i’m sure it’d be available @alfa and heera panna for less than 15k.
if you don’t mind a bulky cam, i guess D40 suits ur need perfectly.
btw, i just saw the kodak v705 on jjmehta, its also a wide angle(23mm) and has 5x opt zoom. you can check that out too. it looks pretty cool.
thanks a lot…that KODAK looks good and has USB2 which the panasonic did not have
Canon SD800 IS Digital ELPH Review: 1. Introduction: Digital Photography Review
Might want to look into this model.. from what you specified, this appears to be a good choice too.
hey did u finally buy one? and which one. I’m looking at the 800IS(260$s with shipping and tax)..thinking of getting it from US thru a relative coming over to india soon.
hey, how about this one:- [it has 23 mm lens not 28 but thats even more wide]
"A unique feature of the KODAK V705 is its dual SCHNEIDER-KREUZNACH C-VARIOGON lens. It combines a fixed focal length 23mm ultra wide angle lens and a 39-117mm optical lens, each with its own 7.1-megapixel image sensor allowing for an Ulta-wide angle and a midrange telephoto. "
FROM STEVE DIGICAM SITE
get the latest from sony DSC-800 6X OPTICAL ZOOM 8.1 MP.IT COST ONLY 10000 AT ALPHA VILEPARLE
really? if thats the news its gr8. btw any reviews of the same out yet? does it support OIS(opt image stabilization)?
Sony T100 nice cam within 25k range I am loving it
Nikon Coolpix P4:
8.1MP Resolution
3.5Xoptical 10XDigital zoom
Vibration and Noise Reduction
Go for it its really great i used it for 5 months and it works like a charm
