Help Needed In Correcting Start-up!!!XP
Hello There!!!my WinXp Proffesional SP2 was messed up pretty bad with virus, malware spyware etc. i wasable to get rid of most (welli think so) using avg(frre version), spybot etc. but now at startup the Windows gives me error messsages like-
Windows cannot find’C:\WINDOWS\inf\Other.exe’.Make sure you typed the name correctly, thentry again.etc etc. and
Could Not Load or run’C:\WINDOWS\inf\Other.exe’.specified in the registry.Make sure the file exists on your computer or remove the reference to it in the registry. and
Windows cannot find’C:\WINDOWS\system32\config\Win.exe’.Make sure you typed the name correctly, thentry again.etc etc. and
Could Not Load or run’C:\WINDOWS\system32\config\Win.exe’.specified in the registry.Make sure the file exists on your computer or remove the reference to it in the registry
in the work account
Windows cannot find’C:\WINDOWS\system32\WinSit.exe’.Make sure you typed the name correctly, thentry again.etc etc. and
and it has an entry even for adminitrative account
.guys how do i get rid of thses things???
also in my computer on the disk drives whenever i double click the drves it says-
Windows cannont find’copy.exe’. Make sure ou typed the name correctly, then try again.To seearch, etc ect.
to open the drive i need to right click and then select open which the third option…the first one is autolpay, clicking which the above sequence replays… wht should i do!!!please help!!!
you possibly must still be infested with the virus and bots…or maybe while u were busily removing the malware and stuff u might have deleted some imp files…
Anyways I would suggest you to re install ur XP…backup C and then format C and install XP again
The virus is gone but the registry entries made by the virus is still there. Search google for Sdfix to restore your registry entries. Most probably, you can’t run regedit and cannot find folder options. In case you can find folder options, enable show hidden files and show system files. Then u’ll see the autorun.inf file on your drives. Delete them to get rid of the cannot find copy.exe error messages. Once you run sdfix, folder options will be available if it was not there.
Also, disable autorun on removable drives AND always right-click>open pen drives so u don’t get infected again as most of these viruses spread thru pen drives.
Looks like your system was pretty knocked up (if I may) by spyware and malware.
If you are comfortable with XP re-installation, I would follow cynozure007’s sound advice and backup my data and go for a complete re-install. Not only will this, get rid of any loose ends (crippling effect) left by the spyware/malware, it will also breathe fresh life into your system, making it feel zippy like when it was new :slight_smile:
However, if you have no other option and need to fix the problem, insert your XP installation disc and select the repair option. This should fix up most of the issues you are facing.
