Help on core components.
I’m planning on a system upgrade soon. I’m currently on an AGP-Based machine and I want to upgrade to PCI-Express. I’m a gamer so I want a decently powered CPU + Mobo + RAM + HDD combo. I have alloted about 15k-20k for the upgrades. I won’t be buying the graphics card now though. Going to wait for the 8900 series to be released.
So please suggest to me a decently powerful CPU + Mobo + RAM + HDD combo for 15-20k.
I was thinking of AMD Athlon 64 x2 4800 + Asus M2N4-SLI + 2 GB Kingston + 160 GB Seagate. Would that fall within my budget? Or should I go for the Intel Core2Duo brand? Help please.
will u buy 2 gfx card? if not u dont need sli
1> c2d e4300 5.2k
asrock or asus 945g mobo 4.5k (asrock is cheaper i think)
ram 2 x 1gb ddr2 667 (for dual channel) 4.5 k
hdd 160 gb (no idea of price) ~ 3k
[prices at kolkata] total 17.2 k
the c2d will oc nicely and give performance equal to c2d 6600 :wink:
OR
2> amd x2 3600+ 3.4k
asus mobo [higher models](get jetway if u can) 6k
rest same total also approx same or u can take a mobo at 5k and get
a larger hdd instead
i think you dont plan to OC incase you do the 3600x2 is a good buy also.
the 4800x2 - 8.5 k
m2n4 sli - 5.5 k
1x2gb ram kingston 667 mhz - 3.2k
160gb hdd - 2.5k
falls within 20k
but i would suggest u get this.
E4300 - 5.3 k
asus p5nsli - 7.5 k
2gb ram - 3.2k
hdd 160gb - 2.5k
gpu - 7100gs or something for 2k
thing is you can take the the e4300 @ stock cooling upto 2.4 2.5 ghz without any trouble and i will be much faster than a amd counter partthen, incase you dont want to oc the configuration then i think you should settle with the onboard graphic of amd and wait for your gpu. but if you dont plan sli get your self a cheaper amd mobo the biostar if you can find at 4.5k is a good buy. or the amd m2n mx at 3.5k .
dasgupta beat me to it. :slight_smile:
I’ve never OC’ed anything in my life, so yes, I don’t plan on overclocking. I heard that the 3600 X2 is a great buy, if you’re into overclocking, but since I can’t OC, it’s pretty pointless buying that processor. So, in case I get a 3800+ X2, an Asus Board, 2 Gigs of RAM and a 160 GB HDD, and in the future if I add an 8900 GTS/GTX, will the GPU get bottlenecked by the CPU?
AMD Athlon 64 x2 4800+ = 8.5k
Asus M2N4-SLI = 5.6k
2 x 1GB Kingston DDR2 667MHz = 3.4k
160 GB Seagate = 2.5k
buy a X2 4800+ minimum if you don’t want to OC & want to use a 8900GTS/GTX when it releases :slight_smile:
you had already chosen great components totaling to exactly 20k :stuck_out_tongue:
no use going for a Core 2 Duo system in a 20k budget
^^^ yep, for a non OC’er its a good config, thought the 4800+ was cheaper tho, wasnt it??
on a sidenote, get urself a bigger HDD, 320Gigs for 4200 and 400 Gig for 4800, 160GB HDD is so last yr :unamused_face:
Hmmm. After some talk with my dad, budget has been lowered to 15k ONLY. :frowning: So I can’t go for the X2 4800+ setup. :frowning:
Anyways, if I do overclock, how far can I push an X2 3600+/X2 3800+ ? Can I push it to a speed so that it doesn’t bottleneck the 8900 GTS/GTX?
Suggestions now since we’re working with a very tight budget?
if you have a 15k budget buy a X2 3600+ Brisbane 65nm 1.9GHz for 3.5k
it will easily OC to 2.5GHz with the stock cooler & thus won’t bottleneck the 8900GTS/GTX
yep, get the 3600+ for 3.4K (make sure u get the brisbane, has 1MB L2 Cache and runs at 1.9Ghz, the Windsor core runs at 2.0Ghz so check the box before u buy)
get the motherboard u r interested in, should be able to OC to around 2.5 - 2.6 Ghz easily on stock cooler
But the problem is, I have no clue on this overclocking thing - is it easy to push it to 2.5 Ghz for an overclocking n00b like me? :unamused_face:
Hmm, yep, since we’re working with a tight budget here I think I’ll be going for AMD Athlon 64 x2 3600+ / Asus M2A VM / 2 GB Kingston 667 Mhz / Seagate 320 GB combo
buy Asus M2N4-SLI for 5.6k or Jetway M2A692-GDG for 3.5k
don’t buy anything else
there are enough people to help u on te and loads of reviews here n there.
get your self this
amd 3600x2 + asus m2nmx or Jetway M2A692-GDG - 6.8 k
2gb ram - 3.3 k
hdd - 4.9 k 400 gb hdd
15k done :slight_smile:
go with the cofig 200mph suggested, but watever u do, dont get the asus m2a if u wanna OC
yes a noob can OC with a lil help and practice
So is the Asus M2N-MX ok for OC’ing?
ya it is a decent board , read around you will see you can take it to 2.4 2.5 ghz!
yep and so is the Jetway 690G; get any of em
but since u r not going the discrete graphics card way, would suggest that you get yourself the Jetway 690G; way better graphics then m2nmx tho not as good as any low low end discrete solution (6200TC)
I’m not going to be doing any gaming until I purchase a PCI-Express graphics card, :slight_smile:
Right. This is what I’ve decided to get in 2-3 days. Or whenever I get the cash, max 1 week.
[I]AMD Athlon 64 x2 Brisbane 3600+ @ 1.9 Ghz - 3.5k
Asus M2N4-SLI Socket AM2 ATX Motherboard - 5.5k
Kingston 2 GB PC2-5400 DDR2 Memory @ 667 Mhz - 3k
Seagate 120 GB 7200 RPM HDD (Will add a bigger HDD when I get my GPU) - 2k[/I]
Total ~ 14k
I’m going in for the Asus M2N4-SLI as for some reason I prefer ATX over mATX :unamused_face:
Anyways. A question. I heard that Transcend JETRAM sticks which run at 800 Mhz are pretty good, any idea how much they cost? Or should I just stick with Kingston? :thinking:
kinstons and transceds cost nearly the same some 100 bux difference either way usually
one little thing u missed, the motherboard u picked up, no onboard graphics so u’ll need a temp gpu for the mean time like the sub2k 6200TC
Nah man I don’t want to add a low-end solution now dude, will get a better graphics card somewhere down the line :slight_smile: I mean I can run the PC with the parts I just mentioned right :slight_smile:
dude what are you talking . its got no graphics , means no vga port how can u run the pc without the screen getting display ? lolz . u will have to buy a low end gpu if u want that else get the board we suggested you.
