My bro told me to post this for the help for his cell.
he can only save sms in phone memory. He cant store messages in Memory Card and it limits to capacity around 200 messages. If anyone knows how to save messages on memory card will be very helpful.
-Beast-
nopes ⦠canāt be done on CID49 phones, so far:(
Iāve tried it 2
it doesnt work
WOTANSERVER - SonyEricsson debranding and firmware update online service some other forum members(google search) suggested this site. they said that this site has latest firmwares and will void warranty and u will b able to save messages on mem card.
You canāt change the CID , if you want to flash the firmware you can also use DaVinci Team or cruiserlogs.net for the newer phones
If you gotta increase the sms storage on a cid 36 phone ⦠http://www.techenclave.com/forums/k750i-w800i-unlimited-sms-storage-77054.html
Dammit waitin for CID49 to breakā¦
Last I heard you could break into the CID49 system and see the files , but you couldnāt read or modify them ⦠or will end up with a dead phone
Its not worth screwin 16K cellā¦
Well am fed of Msg limitā¦200 itss way to lowwwā¦ok the more..andit will slow down..but atleast 400 shuld be there..1!
Btw..damn any firmware update for High āMax Volumeā..coz the current one is nt MAX enoughā¦!!
well wid earphones and Mini speakers its classicā¦bt widout itsā¦it just isnt enuff
any help guyz? still waiting!
CID49 is already broken. yes with DCU-60 cable (that comes with your mobile)
try this tool first: http://forums.se-nse.net/index.php?showtopic=6807
guru, XS++ isnt working (software which is on that forum link) any other alternatives?
Guru busy with Ashbaby:rofl:
@ Stick
lol
@nvidiabeast
when you xs++ didnāt work what exactly didnāt work?
Gslide may help you
This is a new slider which also has the ability to patch, which means the first VKP-patcher for CID49 phones!
A patch from CID36 will work on CID49, just remember firmware version
tutorial: GSlide - SE-NSE Forums
double post
ill try this new stuff today when i reach home in my broās cell. lets see how it works out to get unlimited sms storage
I think any attempt to flash the phone will VOID warranty. Did you get sucess to increase the SMS storage?
no man. i am not finding latest flash ROM any help finding it?
