Ok first things first
Can the light be turned off ?
Second, how to set the DPI.
Third, how to configure the side buttonsā¦
the light cannot be turned off.
download its drivers to set the dpi.
download its drivers to configure the side buttons.
first - no
second - install razer drivers
third - install razer drivers
with windows drivers, dpi can be adjusted with the right side buttons, right side first button increases dpi, second decreases itā¦
EDIT: Udit beat me to it⦠sigh am getting old
Ahh ok, got the 2nd and 3rd points sorted out.
So, nothing can be done about the first :S ?
remove the mouse usb from the usb port
hmm you can open up the mouse and remove the LED thats one way to turn off that light for good lol
LOL why do you want to turn off the light? Hurting your eyes? Easy to solve this problem⦠sell the CH and get an MX518
^ LOL anish you want to exchange it with a mx 518? :happy:
^^if he wants to exchange i have a mx518 bought just 2 weeks back with 1 year national warranty..
Ahh, thanks for the suggestions guys
@ Sandy, Saiyan - No thanks
I wanted to turn off the light cause the room looks āGreeenā at night when the PC is downloadingā¦
^LOL!
I think the led looks sexy.
Anish, disconnect mouse My diamondback is a lot brighter because itās transparent, but whoās complaining⦠serves as a red nightlamp
Use duct tape
Put a cloth on it at night simple , i too did that when i used my microsoft optical
mouse which has a red led.
