I can’t see any option how to edit my own thread’s title. For eg: If i started a question, & found an answer to it, I would like to change thread title to SOLVED: to notify that this thread HAS the answer as well.
Good Idea, but you can not change Edit the thread title (for that matter, your own posts after an hour or so). You can request the Mods to do the same.
This process will become a lot simpler in a month or so after we do an update.. At the moment, as gmano said, you just have to ask the mods.
you can not edit them.. i have tried already
You can edit the thread title within a very short while… I could do that.
You can edit as said already to do either click on edit button and change the title through Advance editor.. or open up the forum point towards thread and double click on the blank space near the thread not on the link and you will see a editor which will let you change the title http://www.imgx.org/pfiles/3702/Screenshot.png
@ DArk star
I couldn’t get what u mean to say. can u guide me in steps’ or with marked screenshots ?
Anyway this is the thread in question
http://www.techenclave.com/forums/presario-v3611au-xp-drivers-101343.html
Thats applicable only to mods
dats wat…so only mods can edit the titles right ? coz its sometimes is troublesome to get the title changed via mods, especially in the market section…
