insane CPU temperature
thats kool gcbeldar..
as for me, right now the proccy seems to be working fine at stock, so am continuing with it, as I’d prefer not to have any downtime lasting for days :stuck_out_tongue:
thanks for the help guys!!!
It is safe to run the CPU undervolted, but do run a OCCT stability test for atleast 2 hours to make sure that the CPU can run at the low voltage.
You can use RMClock here to force the CPU to run at a lower voltage, while keeping CnQ enabled.
Check the guide in my sig.
PS: I’ve been experimenting with a Windsor 5200+ (90nm, 2.6 Ghz) in my office and I got it to run stable at 1.25V @ 2.6 Ghz (stock).
I feel that the newer Brisbane 65 nm chips can go even lower.
I’ve gone round and round about my ma78gm (v1.0) and amd X2 5400
overheating.
I’ve replaced the mobo once, and still get the issue. Now I can run the
cpu at 7x or 8x (around 1.5Ghz - cpu is rated at 2.8Ghz, or 14x multiplier)
with things like Einstein@Home, Folding@Home, Apache and JBoss running,
nothing else. Any graphics game pushes it to the warning (over 70degC)
within about 15 minutes (I turn off Einstein and Folding when running games).
I’ve decided to RMA the processor as well; the stock AMD hs/fan is the
basic aluminum one; no heat pipes. I’ve also ordered a Zalman 9500 AM2,
since the HS mount bracket has the plastic flanges and the Zalman AM2 has
a bracket that fits the flanges (I hope - the 9500 AT had a square bracket
that did not fit the mobo - the stock cooler bracket is rectangular, not
square).
Even if the stock HS/fan is not the issue, maybe I can use the Zalman to
overclock it.
Anyway, I’ll report the results here. Sounds like more than a few people
are having overheating issues with this mobo.
hey dude did yer pc ever shut down cause ofthe overheating?? if not, then it may also be a case of screwed up sensors…
