I have some doubt regarding Internal TV Tuner Card. I am purchasing one from my friend.
The config of my PC is. PIII 1Ghz, 64SD RAM . I wanted to make sure that
Internal TV Tuner Card will work properly on my PC without any glitches. I also want to record with its help..!!
I am not sure abt the model..but is of Proview…
Because somewhere i heard that Internal TV Tuner Card Need min of 128 SD RAM to work. Is it so ?
So any ideas , suggestions..??
BTW do anybody have idea abt this Proview TV Tuner Card. I mean its performance and all…
Regards,
Dipen
The TV Card shud work but the problem could arise at the time of realtime recording in mpeg2/dvd pal formats..the best possible way out is to try low(est)-fi recording quality (though not sure tht will work or not..)or the more expensive way out is to get a memory upgrade
I have a ADcom TV tuner card which i brought like 3 yrs back when i had windows 2000. I have XP now and couldnt use the card at all as the application crashes when i try to switch to TV mode. My card driver are properly installed and its detected by XP without any issues.
Anyone aware where i can get hold of a application which works on XP?
It depends on the TV APP…and your card quality…though in most cases you cannot record in DivX format directly from your TV card. :no:
And yeah, be prepared for ram upgrade as it is inadequate for viewing also. Also which OS are you using now?
I have a compro videomate TV FM card and the system requirements for it are as follows..
(from the compro website):
Minimum Product Requirements
* 400 MHz CPU for TV viewing
866 NHz CPU for recording and timeshifting
1.7 GHz CPU for DVD-quality recording
* 96 MB memory for Windows Me or 98SE
* 128 MB for Windows XP or 2000
* 10 MB free disk space, plus approximately 2.5 GBytes per hour of video recorded at S-Video quality
* Sound card with Line-In connector
* Open PCI slot
* CD-ROM drive for software installation
So, even the requirements for your card shud be more or less the same..
I have the COmpro VideoMate Gold 2 plus tv tuner but had a sad sys…p3 866mhz with 128mb…
I cant record anything above 384x288 res in any format…mpg/mpg2/divx/xvid as many frames get skipped in the recorded video.
I can get the best rec. at 384x288 res in mpg1 format.
So i’d suggest u to add atleast 128mb of mem before u buy the tv tuner. Also u’ll be limited to just mpg1 recording.
yes..guys… I know i will be needing RAM..but the problem i am facing..is…this SD RAM is way too costly… i just enquired yesterday..and for 128 MB the cost is 1300/- and for 256 its 2100/-…
