This guide is for people out to buy dvd players/consoles with divx/xvid playback capability.
Since the advent of the divx and xvid format people have been busy compressing and fitting around 5-6 movies on a single dvd-r. However the movie experience wasnt complete while watching on a PC monitors and so were born the hybrid dvd players equipped with special chips that enabled them to play divx,xvid and a lot of other medias. However one can be easily confused with all the options available. I hope this guides enables you to make your buying decision.
PS: I am also including gaming consoles that can provide similar functionality.
Philips DVP 642k: Once a great choice for playing divx and xvids has lost its charm due to lots of problems mainly unit and len failure. The player is equipped with a Ess Vibratto II chipset which sadly only does normal divx and xvid no QPEL and GMC encoded xvids which is a major drawback. Although the player supports almost all kind of dvd-r, +r and dvd-rw and +rw and cd-r and cd-rws as well. Some cheap medias might have problems playing though. Divx subs also supported with the latest firmware. If you are lucky you might still find it in stock. But not recommended unless you dont have a choice. Price: NA (4500 Rs last heard) http://img347.imageshack.us/img347/8319/philipsdvp642k4le.th.jpg
**Philips DVP 5500 **: This another player from philips lived quite a short life. Its dint have the problems of the dvp642 mainly sudden death and lens failure. However still being based on a vibratto II chipset which did not support the full divx and xvid specs it’s not a good buy either. Supports all dvd media formats. The picture quality was good though. Philips have slowly removed this player off the shelf to make way for newer players. Price: 4750/- http://img188.imageshack.us/img188/606/l141402505rf.th.jpg
**Philips DVP 5100 **: Finally philips learnt its lesson the hard way. It finally incorporated the mediatek 1389 chipset in its player and now all the qpel and gmc related issues have been solved. However u need to run your media through mpeg modifier to change the settings if its packed bit stream. Apparently packed bit stream will not play fluidly on it. But changing the settings is not a big deal. Xvid and divx subs supported and most media will work smoothly. This player is definitely recommended. Price: 4750/- http://img188.imageshack.us/img188/8669/2519250kr.th.jpg
LG LDA 530: Lol try as i might i couldn’t lay my hands on this player though LG people say that it is available in india at major showrooms. MTK 1389 based. Price: NA http://img188.imageshack.us/img188/7067/lda5308ld.th.gif Sony Ps2: Not a divx player by default but there are a few homebrew softwares that will run on players with memory card exploit or easily on a modchipped ps2. However since doesnt have the juice to play divx, xvids with hi bit rate i.e. 1MBps though it handles dvds good. Price: Varies. http://img188.imageshack.us/img188/4158/ps28lj.th.jpg MS Xbox: Install XMBC and make sure you get a xbox with a philips dvd-rom which supports most media. After installing XMBC you will never have any problems playing any kind of media xvid, divx, ogg, ogm, all container ands codecs supported. Also unlike other dvd players the xbox will be easily be able to play future formats after inclusion into the latest xbmc builds. So u wont ever need to run out and get another dvd player since a new version of the codec has come out and has features that the player cannot handle. The p3 700Mhz does good work. Added plus: games Price: Varies http://img252.imageshack.us/img252/4886/xbox3bu.th.jpg LG lx-d 5640: a Hi-fi system with mp4 and divx playback. Unofficial supprt for xvid too. No idea about the chipset though most likely should be MTK 1389/EE/GE
Price: NA http://img102.imageshack.us/img102/3528/lglxd56402qu.gif Mitashi 555: Based off the mtk 1389 chipset but flawed in execution. Crappy firmware makes this player a not so good chioce. recommended over the 642k though if you don’t mind the looks. Flimsy build quality. Price: 4300/- or lower. http://img261.imageshack.us/img261/7410/13662268divx5554jw.th.jpg Mitashi 999: Based of the 1389GE/EE chipset and supports everythng under the sun. However build quality and looks are nothing to boast about. Get it only as a 2nd option to the 5100. Price: 4999/- http://img347.imageshack.us/img347/8145/mi1001lg0ok.th.jpg
Lg, philips, sony have introduced hi-fi players which play dvd, divx, mp4 but i havent chked them out yet. If anyone has done that please post in here so that others may benefit.
Philips DVP 5500 :However still being based on a vibratto II chipset which did not support the full divx and xvid specs it’s not a good buy either.
Actually the DVP 5500s player is also based on the Mediatek chipset.
it’s wrongly mentioned it supporting the ESS vibratto II on the videohelp.com website.
BOth the 5100 and 5500 are based on the same chipset.The difference is that the 5100 does not have DTS decoding.
There was one page in some forum where i got this info about DVP 5500s.
Also for verification - it can be seen that the DVP 5500 only displays the subtitiles of those movie files which have the same name as the avi itself.
It is not like the DVP 642 where you can select the Subtitles file which could be of any name. This is the major difference which is immediately evident between the ESS and Mediatek based chipsets.
Also the 5500 played many Xvid files that the 642K was not able to play.
I don’t own this player but my friend has it. Maybe an owner can verify more.
So imo the DVP 5500 and DVP 5100 shd be the best buys- with the former getting more preference coz of more features.
Dunno where jimmy got the info about 5500 having mtk chipset but i was pretty sure abt it having a ess chipset. Hence they r removing it to make way for the 5100.
Some Guy(in the middle stages of the thread) has placed the original firmware info from his player - which shows the player to be based on the Mediatek chipset.
Although my findings arent based on net research I was actually out looking for a good player. I’ve tested xvid and divx samples with the 5500 and it wouldn’t play the xvid gmc and qpel samples. This is typical behaviour exhibited by the ESS Vibratto II. Though there could be a slim chance that philips has now started equipping the 5500 with the mtk chipset. If indeed it’s so then could u plz test it on your frnds player ?
hmmm…curiouser and curiouser.. I was about to go get this player today evening or tomm. But now seems like i will have to wait.
I tested 3-4 movies that did not work on the 642 specifically..(i.e worked with jerks or hazy playbacks) and all seemed to work properly on the DVP 5500.
One of them I am sure was QPEL encoded.
Most of the Mediatek players at this time do not support GMC and Packet bitstream. (Atleast the Mediatek chipsets only support part 1 of the GMC specs..the QPEL is 100% supported). However unlike the ESS they do support QPEL encoded videos. Perhaps you can test some QPEL encoded videos- i think they would work on the 5500..
I would not go for DVP 5100 - simply because it does not have DTS.. My impression always was that 5100 and 5500 share the same chipset and that the 5500 is the one with more features - which seemed to make sense as per the naming convention.
I doubt if philips wud ever change the chipset without changing the players name. I will try and test more movies on my frnds player when i can..
Thanks Blade_Runner for the info..
Hopefully someone else can comment on this also..I am really hoping to get a DVD player soon..(with a Mediatek chipset - no less
Like i said philips might have started using mtk chipset with the 5500 now. So the one u tested might b mtk based and the one i did might b vibratto ii.
Yeah i am aware of the fact that the whole GMC spec is not supported, one of my main reasons not to get a divx player now. and i think i posted b4 that i tested some qpel and gmc samples with the 5500.
True but still the above argument stands about the chipsets.
Last week i was out with my friend to buy a DVD player for him…in Blore only 2 models are available in most stores… DVP642K and the 5100 (As far as Divx players) are concerned…others like LG and Samsung had higher end models with speakers… but the 642K was in abundance…i still wonder if it has been phased out :S … another drawback of 5100 is that it has got a 2.1 output as against 5.1, something a DVD player must have according to me…
Mitashi has its dealers only in mumbai…nil presence in Blore…even the website has addresses of all Mumbai centres only ,if u guys have some idea bout availability in blore,please let me know..i am sure many bloreans want this … I havent tried the sony showrooms,but i guess there are no affordable standalone players from sony :no: …
