Hi
This is my RiG.
my cabinet have only 1-intake and 1-exhaust FAN (both 80mm). No way for 120mm.
Other time it has no problem, but the HOTTEST SUMMER WEEK, system gets quite hot, below ‘panic temp’ but, like - crosses the temp while loaded when normal weather even if it is not doing much…
My question -
Can I install 2 80mm fans, one-after-another in a ‘grid’ and set them as exhaust system ?
will it help ??
