Onboard network slot - Asus A8NE (driver problems)
Hi,
I am using Asus A8N-E motherboard and have recently got myself Triband. this is the first time I am using my onboard network port. The port kept on showing problems in Device Manager, so I installed the old drivers which came with the motherboard CD instead of the updated nVidia chipset drivers downloaded from the website.
After this the network port started working but I still have to restart the PC after changing IP/DHCP/DNS settings. Also, the DHCP keeps on hunting for the IP and shows similar notification in the tray. Somehow I still feel that this is a driver issue.
Any solution ? If I get myself a wireless card will it affect the triband speed and resolve this problems?
Thanks
^^^try assigning static ip(i.e wrt pc and ur router)…this static ip is different from whch the server assigns to your router…get into the tcp/ip properties of ur network card…manually enter following parameters…
ip address:192.168.1.3
subnet mask:255.255.255.0
default gateway:192.168.1.1
and the defalut and alternate dns servers as entered in your router(default triband dns servers)…save and restart your pc…and then try…hope this works…:slight_smile:
no, the wireless card wont affect your speed…they are sought to support maximum bandwidth of 54mbps…but may affect depending upon the signal strength…
Actually thats the way i an using it right now
are u sure…ok then try removing these settings n check “obtain ip address automatically”…btw was it working properly bfore this problem occurred..???
No. Doing that doesnt help. Its been around 8 months that I have got myself a new rig but I had disabled the onboard network port as I was not going to use it until now. This is the first time that I have enabled it. I know that it cannot be a hardware problem as it is working with a set of old drivers (provided on the mobo CD). Also, the router’s DHCP may be a problem by itself isnt it (I actually checked it on my notebook and found that the DHCP was working fine).
I was just wondering what is causing my PC’s network card not to pick up the IP from the DHCP. I tried manually releasing and renewing but that doesnt help either.
ok…
  1. are you using windows xp sp2..?
  2. is your net working fine on your other system(laptop/pc)..?
  3. is dhcp enabled in your router settings..?
also try this thing…under tcp/ip properties, click on advanced and under “WINS” tab check “enable NetBios over tcp/ip”…see if this helps…and do get bck with the queries…
^^ Yes for all the above questions.
This seems to be a driver issue definitely.
try WinSockXpFix
if your tcp/ip registry entries are corrupted this might help…
