Optical drive suggestions.
Hi folks,
My 3+ -year-old Liteon DVD drive seems to be dying and I am thinking of an optical drive upgrade soon. The other drive I have is a Liteon CD writer and is working fine.
  1. Should I go for a DVD writer combo? If so, which model No? How much will it cost?
  2. What would be an less expensive alternative?
  3. I am flexible on budget, but I want a good, trouble-free long-lasting product.
  • DH
SONY awg170a 18x dvd writter with bit setting firmware available price is 1900 in delhi
..btw wait for techead to reply b4 u go and buy :slight_smile:
Get the Asus 1608 and flash it to a Pioneer 111L lightscribe drive :slight_smile: Slightly pricier tho, Rs2200 or so.
Raghu.
Or even the LG H42N. Get the LG or the Asus.
Hey guys, thanks plenty. Are the LG ones good? I don’t like LG too much! Got some bad experience with them.
Please confirm if this is the Asus one. What about the Sony? Any good ones from BenQ or Liteon?
Nope. Get the 1608 PS3. Anyway, the only one you will find in the market is the 1608 PS3 and thats the good drive. The LGs are good too. Benq, Sony arent that good these days, as they used to be about a year ago.
Raghu.
1608P3S, not the PS3 :stuck_out_tongue:
Benq - if you get the 1640, 1650 or 1655 only..
cost wise LG GSAH42N is around 600rs cheaper…i just bought 1 today for 1700…most of the LG drives i have used in the past few years have given excellent quality burns.
^Netbakwas, where in Mumbai?
Hi guys,
What is the essential difference between LG H42N and H12N.
  • just before I get the stuff.
Another vote for H12N
@Doc - 8X -RDL speeds in the H12N, 10X in the H42.
Get either of them.
from this thread…
LG GSA-H42N : Post your scans and questions here - LG DVD Burner - Club CD Freaks
post no 10…
so now the question is:
what are the differences between the H42N and the H12N ?
just 10x DVD+R DL speeds ?
Post No 12…
Different chipsets, H42N uses Renesas R8J32032HFPV chipset and H12N uses Renesas R8J32018FPV chipset
post no 15…
the difference is only write speed 10x -DL for H42N and 8x -DL for H12N
post no 18…
So the unique improvement are 10x -R DL
ALL this excitement over a 2x boost in -R DL writing speed !! :frowning:
EDIT: Oooops TechHead beat me in the reply… :slight_smile:
I was quoted a slightly higher price for the H12N !!
Thanks Easy and TechHead,
@ Easy, that was sure was real hard work mate.
  • DH
u get them for that price everwhere at lamington.
