guys I’VE DECIDED ON THIS system its details are::-
amd x2 4400/4600
msi k9agm2-fih
kingston 1gb ddr2
viewsonic Vg1930WM
creative soundblaster 5.1
SMPS : coolermaster 380w
160 gb SATA-II seagate or WD
liteon pata dvd writer
MAX BUDGET=35K
MY QUERY IS WHETHER K9AGM2-FIH WUD BE ABLE TO SUPPORT 19"LCDAT DECENT RESOLUTION (MENTIONED ABOVE)
ALSO COMMENT ON ASUS M2A-VM HDMI, IT HAS ALL THE FEATURES BUT I’VE HEARD SOME PROBLEM IS GOIN ON WID DIS MOBO RELATED TO MEMORY OR OTHERS. DON’T WANT TO GO 4 JETWAY MOBO. ALSO, IS THERE TOO MUCH DIFF. BET 17" AND 19" LCD IN VIEWING. THANX IN ADVANCE.
thnx deepak ur other posts and this one has helped me to learn a lot regarding computer hardware selection.
thru ur early posts i am already aware of msi and asus aftersales wonders(joking). i am more keen to go 4 asus m2avm-hdmi board, but as i’ve mentioned in my early post, thru website i’ve come 2 know about some problem goin wid dis board (newgen.com). please clarify.
sorry man, cant help with that, I personally have not heard of any problems and I doubt that any member here has it, can you give the link of what kinda probles there are?
two guys mentioned bout da memory probs. neways leave it out, which of these 2 mobo u wud personally suggest. tom m finally goin 2 buy. and is dere any addition u suggest to b made.
