hey, I am considering purchasing System Mechanic 8 for $19.95. But I want to know about its performance. Is it worth? I have not been able to find any helpful review on the net and hence want to know if anybody here has tried the software.
System mechanic used to be good before. I was addicted to version 5/6 and found it to be handy. But I feel its become bloated, and does not actually do much of what it claims. I personally wouldn’t recommend spending money on it. If you want to clean your PC of unwanted files, use ccleaner
Til version 5.5 it was fine i hated 6 and stopped using that.. i don recommend on buyin .. Using Ccleaner +diskcleaner + Tune Up 08
