Sig Problem
Whenever I add a fifth line to my sig, its gives this error :
  1. Your signature contains too many lines and must be shortened. You may only have up to 5 line(s).
Now, for eg superczar’s sig (just an eg buddy, no offence meant) has technically 9 lines due to the spacing.
What’s the issue with mine ?
its dependent on no of characters from what i know. Amount of characters / line is predefined ( i am not aware of exact no. ).
Thats why the problem. I am not able to get my entire rig in as well due to sig restrictions and wcg tags. but thats the limit set. :slight_smile:
^ See this SS. One char per line. One space in between each lines so technically 9 lines, exactly the same the SC
http://www.imgx.org/pthumbs/small/545/screen.jpg
Now Superczar’s sig too has 9 lines.
Could somebody shed a bit more light on this ?
Hey Anish, wait for the admin to reply…
Anybody ??
If you’re in a hurry.. for the time being you could PM me the sig you want (with all the formatting etc). Apparently mods can change sigs without hitting these restrictions :wink:
That should do, till the admins figure out the problem.
whats the need of such long sigs btw ? want to wear out our scroll wheels ? :stuck_out_tongue:
^ Hehe, np, I can wait :stuck_out_tongue:
can we also have a little bigger siggies???
i think 40kb is kinda wayy to small.. it really jacks up the quality of sig.
or better yet why cant we jus have the tags in our sigs :frowning: :frowning: :frowning:
The issue of bigger siggies has been discussed n number of times and the answer is no, we are not allowing bigger signature.
^ Great, now can somebody still explain why I can’t add a fifth line :stuck_out_tongue:
from the screenie, i’ve noticed you’ve blank lines in between the other lines.
remember, those blank lines also count towards the total no. of lines allowed.
remove those blanks and check if the prob exists. :slight_smile:
^ How does his Sig work ?
http://www.techenclave.com/forums/members/superczar.html
Its all monitored by the forum software and according to it - “Unfortunately, due to browser and style variations, this is not an exact science and should only be used as a rough guide. Soft linewrapping can cause one contiguous string of text to be counted as multiple lines. Text that is not the default size is scaled to count as more or less characters than normal.”
And the allowed maximum font size for signatures is 2. Hope this helps. :slight_smile:
As for superczar’s sig - better ask him. He mite be able to share a trick or two. :wink:
^ Lol, okay :smiley:
