Software for Audio Cleaning
Hi Guys
Do u know of any software for cleaning the audio.
Sometimes there are hiss , pops etc…
Is there any software for removing such distortions from the audio.
magix audio cleaning lab 10…had used it many times, quite decent
more importantly, whats the hardware and software you are using to record?
I found out the hard way that , often,that its the easiest way!
Thanks a lot for the suggestion.
Anything else except Magix…
one more software mp3trim pro
