I brought a sony vaio CR35G for my dad today. I have noticed that the screen is very dull. Very low resolution and the colour production is also very bad.
Suggest me some graphic settings to make it more clear and mush better.
Are you running the display at native resolution? Try changing the resolution a few times and check for sharpness.
The resolution is correct. The problem is in colour.
get it checked !
show it to the ppl. at sony world and they’ll guide you..
You can’t expect such a thing from a new notebook!
^^OK. I will check. But those guys look fools to me. Can they really help/advice.
then go to some private service centre.
HI DriftKingNT
I am also considering to buy Sony VAIO VGN-CR35G/L. How is its overall performance ? any help would be appreciated !
Thanks,
Ankit
Sony Vaio is the best in terms of build and quality also better than the crappy dell.
