Suggest a Digi CAM
Hi there!
Guys please suggest a digi cam
Budget 17-20k
I am not sure wheather I want a photographers type camera with all fancy adjustments or such or a simple type… point shoot click…
Please suggest models of both type… will check out its features…
Buy the Sony Cyber Shot DSC-H1 for 19k
Buy Sony Cyber Shot DSC-H1 / 5.1 Megapixel / 12X optical zoom / 32MB / Digital Camera Online at INDmall.com
or the Sony Cyber Shot DSC-W70
Both are great Digi Cams my Cousin uses the Sony Cyber Shot DSC-W70 himself & just loves it
Canon’s give more natural colors…check out the powershot A710IS. brilliant compact model.
For a pseudo DSLR try the S3IS
links please!!!
will help a lot
Digital Photography Interface :: Canon PowerShot S3 IS Review
Review: Sony Cybershot DSC H5 compared to Canon Powershot S3 IS
Canon S2 IS or S3 IS are your best choices. Will give you DSLR type looks and some of the DSLR functions with an ease of use of a point and shoot camera. Not sure about the cost though.
S2 IS
Canon PowerShot S2 IS Review: 1. Introduction: Digital Photography Review
S3 IS
Canon PowerShot S3 IS Review: 1. Introduction: Digital Photography Review
Canon S3 IS is for around 20k
If you could spend a bit more, a Nikon D40 is within reach… atleast in grey.
CANON S3 IS — PERIOD !..
17.9 k GREY - ALPA STORES…
WITH WARRANTY approx - 24k
Im using Sony DSC W-70.
It is pretty good but then i dont know much about other cameras…
Cell Phones, Digital Cameras, Jewellery, Toys, Car Accessories, Kitchen Appliances, Audio Video, Computer Peripherals, Apparel
S3IS is good but outside of your budget..
Look at Canon A710IS or A630.. I have the A710IS and its great
S3IS sucks indoors and with less than ideal lighting. I’ve tested it. Bought two for friends back home, and they ain’t satisfied either.
The powershot a710is is good.
S3-IS is out of the budget for local buy but imho, the best cam for 20k is the w100 fron sony. Its a 8mp cam and contrary to the w70, it uses a 1/1.8" sensor, which is a bigger sensor and hence better pics.
The Sony H series excels at that..that’s the reason I picked up the Sony H over the Canon S
^ Yep the H5 owns the S3 IS indoors, but sadly has noise issues above ISO 400 like most Sony’s :frowning:
I seriously doubt if any mid-end camera is any good over even ISO200
ISO 400, and bot the Sony and Canon get noisy…god forbid if you try going any higher !
