Suggest a Mobile with Loud Ringer Volume
Hello There,
My Cousin using Nokia 2600, he is totally dumbo with Mobile😄
Ask me to buy New (he was took me out to buy 2600 last year), again on Sunday or after (when I node:) )
He compliant that Nokia 2600 ringing to low (even with Volume 5) that every day he missed 2-3 calls and than customers blame him to avoid them.
His priority is LOUD RINGER TONE, Colour Screen, FM and easy navigation. Budget 5k.
Please suggest me.:slight_smile:
Mods,
Please change Title as Suggest Mobile with Loud Ringer Volume
Thanks
MODS,
Please do needful!
You should PM one of them if you want it done quicker..
i am at loss here, i havent got any idea about a below 5k phone with loud ring volume… it would be better if you took your friend to the shop and checked out the phone there…
There are several options like SE K310,Nokia 6070 and Moto flip which are below or around 5..
Get Ngage series. they r loud n nice :slight_smile:
You can try Motorola L6i, nut dont know about it’s loudness, but one think is that they hve very decent ringing volumes. It has FM, Camera etc. It is available for around 6k.
L6 have 56cc volume while 2600 have 86cc
The Moto C168 is loud as hell …with ‘moving train’ ringtone, da default ringtone
or just try to get a Nokia 3310 or 3315…if u can…they were loud as hell ..LOL
yep, 3310 can wake up the dead :smiley:
But 3310 not have Color and FM
If you are looking for colour screen and FM, the Nokia 6020 is quite a nice option. If you do not need the FM feature but a white light will do, then Nokia 1108 rocks!!!
go get the motofone… for 1500bux… its awesome as hell. checked it out :smiley:
although it doesnt have FM or color screen, but its loud enough..
