Suggest an LCD for HTPC
hi guys
which one do u think is the best PC LCD for htpc around 10k in india ofcourse.wanna get one tommorrow.
TIA
options include Viewsonic 1930 or 1932 or LG or samsung 19" ..hw abt asus 19"???
Avoid the 1932 - there are lots of people having problems with this Panel. There is a recent thread here in TE about this. Some panels are now being supplied without the DVI cable - check for this as a cable costs around 600/- :frowning:
http://www.techenclave.com/forums/monitor-problem-99134.html
@eazy
yes i have seen the thread already..so what do u suggest which one will b good for watching movies?
Dont know about 19" Panels. I use a Viewsonic 22" 2245 and it is great for movies. But if I had to buy a 22" Panel again it would be the LG, Dell, Samsung - in this order. Wait for some other TE member to give an answer about the 19" panels - meanwhile check the Dell 19" panel from Raghu’s GO, this will probably be the BEST one to get.
http://www.techenclave.com/forums/go-lcd-monitors-19-20-22-a-97751.html
I had bought a lg the one with 2000:1 dc for a friend (experts say aint matter tht much) one but was tht good compared to the visual quality of 1930
sorry not good compared to viewsonic 1930
Possibly the LG 19" panels are not that great - but I have read very good reports of the LG 22" and 24" panels. Dont forget one thing - Viewsonics A.S.S. sux big time in India !!! One of the worst from what I have read in the forums.
the best one i have seen till now is va1703 i mean for movies this one has amazing viewing angle, cant b said the same about the 19 inchers.
