Suggest: Microphone for Tuning Guitar
My friend has just started learning to play an Acoustic guitar. He wants to use Guitar Pro to tune it and therefore needs a Microphone to connect to the computer. Does anyone know of a decent microphone within 1000Rs that would do the job? And any idea where I can find one?
Edit: Fixed Typo - ‘connect’ for ‘connecter’
Does this one fall under PC peripherals??? :lol:
Umm, yeah. He needs the microphone to hook up to the PC, like I mentioned in my first post. Sorry if I wasn’t clear.
I use a Rs. 75 one and it works perfectly fine with my acoustic and electric :stuck_out_tongue: Ask him to try AP Tuner.
any mic which works would do :stuck_out_tongue:
We kind of assumed it would have to be a good one to help in tuning. As both of you suggested that any mike should do, I’ll ask him to pick up any cheapo one.:cool2:
Ask your buddy to spend that 1000 bucks on a chromatic tuner from Korg or Boss, which will be way more accurate :wink:
Lol.
If u dont know, he did edit the post to make it ‘connect to the computer’ which wasn ther before; so obviuosly twas not meant to be posted in this section if the mic was meant fer a guitar.
Take a chill pill.. :unamused_face:
I passed it on that he didn’t need an expensive microphone. He used the one with a headset and it seemed to work decently for him. Thanks for you help.
@Rio: I told him about the chromatic tunres. He’s just starting to learn playing the guitar. So at present 75Rs solution is more than sufficient is what he said. :stuck_out_tongue: Thanks for the info though. Filed for future use.
@whatsinaname, position the mic close to the sound hole of the acoustic guitar for tuning.
whoa.. whats it with you getting so worked up man… it was just an innocent post asking whether the section was correct or not… not like he’s spammin arnd senselessly…
dint expect these sorta posts from you of all ppl.
Ah, maybe its a mistake as he suggested tat I didn read his post completely.
My pardons, whatsinaname.
Lo’l.
And if I were to spam and collect some reward, I’d hav done tat ages back.
A 30yr old quarelling with a 20yr one. Man, u must be seriously jobless there or tat u’re sick of being a mod @ ur forums.. :lol: :rofl:
No worries. A long three day weekend, maybe everyone just needs to sleep for 20 hours.:cool2:
Jus woke up after a 10hr sleep.. :stuck_out_tongue:
Meanwhile did u find the right mic fer tuning the guitar??
This is the irrelevant replies and BS I was referring to, and you call me jobless. Most of your posts are like this and you question others whether they have posted in the right section. Ace nutjob!
Ok show me another one anywher, where I’ve done the so called spamming/scamming/u-name-it other than with urs!!
Lol, with u is a whole lot diff thing..
