Tomato Firmware 1.20 released!
Tomato is a small, lean and simple replacement firmware for Linksys’ WRT54G/GL/GS, Buffalo WHR-G54S/WHR-HP-G54 and other Broadcom-based routers. It features a new easy to use GUI, a new bandwidth usage monitor, more advanced QOS and access restrictions, enables new wireless features such as WDS and wireless client modes, raises the limits on maximum connections for P2P, allows you to run your custom scripts or telnet/ssh in and do all sorts of things like re-program the SES/AOSS button, adds wireless site survey to see your wifi neighbors, and more.
Just stumbled upon the latest version. Seems there was a problem with the 1.20 initial release, so the author has released a test build. I will try the ND version for my G125, as it is WAY better than stock firmware.
Tomato Firmware | polarcloud.com
nice find, thanx for the update
