How is the Download speed using torrents with a BSNL EVDO connection?
YEah i would like to know the same..
Also the current tarrif and anything else to be know abt it..
Wats EVDO???
The speed will vary according to ur network and the seed/peer ratio. If ur netaork shows full 4 towers with good ratio u get speed varing frm 200kbps in the morning to avg of about 100kbps in the whole day. if ur network is poor then get prepared to get low download speed.
the current tariff i give is after purchasing the device is Rs 610 per month with unlimited download
Hey thanks alot som1053… that was some very valuable piece of information…
where do you live?
is EVDO available everywhere?
sTALKEr you have to check with BSNL…whether they provide the service in your area…
^^ He he no chance of that ! He is from Mumbai where we have MTNL. Gazillions times better than BSNL !
And when are the other operators launching EVDO ??? Wireless internet through mobiles are the most efficient in the sense that they never go down.
Hey,
EVDO technology gives the same IP to many users in the same area. You also are not allowed to open incoming ports IIRC. So torrent incoming ports may not be allowed.
i am in mumbai.. mumbai has mtnl.. nd mtnl sucks!!! :@:@
i mean.. how can you charge 3times as much as bsnl for a simple 256k unltd pack..
nd i was asking coz my dad was plannin to get a datacard from tatti-indicom.. he’s in madras
was thinkin that this might be a better option for him..
[ot] wat was that awesome looking bike i saw parked in your compound the other day? any idea? it was covered with a tarp.. could make out a massive rear wheel nd awesome looking exhaust on it.. it was parked sorta in the portico/front yard of the hearsch ke opposite wala house.[/ot]
junkiedogg, so you mean to say that i wont be able to download using Torrents using EVDO…???
CAn some one else confirm abt the ports and the single IP..??
Yes it is single IP shared with multiple ev-do users.
i m getting awesome speed in torrents.
Thanks a lot Cisco… i am getting the connection… :):)
Awesome!!!
wat time of the day was it??
Is it this high all day??
^^^^ According to the image the time is 01:04 AM
WOW. Thats really awesome speeds. Do you get similar speeds all day long? Also does youtube videos etc play without any buffering delays?
What is the cost to take this connection? Where should I apply?
According to the image the download speed is amazing but the upload speed is crappy.
If you are downloading from Private trackers then even if upload is low it wouldnt be a problem provided you have a good ratio.
Probably Ill be taking this connection soon. Is a PCMCIA version of the adapter available?
