need a tripod for my dslr … where to get it in mumbai ..what are the usual prices i should be hoping to get it for
thanks
thanks
Velbon Tripods from…
M/S. PRERNA ENTERPRISES
Mr. RAJESH BHATIA
9TH FLOOR, MAKER TOWER J/96
G.D SOMANI ROAD
CUFFE PARADE
Mumbai 400 005
Tel.: (91-22) 2269 5464/65/66
Fax : (91-22) 2262 5781
E-mail: prernaindia@roltanet.com
Consider the lens you will be using, rather than the camera itself. What lens do you have currently and what do you plan to upgrade to?
I consider the Vivitar VPT-3600 for ~ 3.6k from JJMehta
