Came across this ad for a wall mount for LCD displays and was thinking of getting it but I thought I would check here first if anyone has any experiences with these things ?
I will mount the LCD panel a few inches above my table so I am not to worried about it falling off I like the idea of having my 22" wide screen in vertical position - imagine the number of lines I can view in forum threads
It looks very flimsy. I am using the one which came with my Samsung LCD TV… that is much bigger than this… and I dont feel like I can trust that itself.
Asking me to trust this wall mount with my 30K LCD TV is a sure no-no.
I saw similar wall Mounts in delta peripherals, seems to be good enough to hold the 22/24" screens. Don’t know more details on this, will check it next time i go there.
If its the former, then i guess it would be fine provided you install it correctly.
But for a PC, i dont like to have a screen vertical, i prefer it has a slope, say 20 degrees from the vertical, away from me, much easier & natural on the eyes. So i’d check whether it allows you to swivel on the horizontal axis cos from the pic, all it seems capable of doing is only rotating along the vertical axis.
To get horizontal adjustment will cost you little bit more me thinks
