Webcam related help required
I dont know where to post this, so posting it in general section.:frowning: Can somebody tell me a good software to take timed snapshots with webcam. I have an intex night vision webcam. The bundled software is useless. It only allows to record avi video. I cannot take timed or cyclic snap shots with it. So is there a 3rd party doftware that can be used to take snapshots. Pleeease pleease help me.
try MS timershot powertoy
http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/TimershotPowertoySetup.exe
Only for XP…doesn’t work in Vista. :no:
Thanks. :slight_smile: Does it support 640x480 resolution pictures? :slight_smile:
yes…it depends on the camera’s H/W capabilities.
That microsoft software is not utilizing the full potential of the cam. :frowning: it takes snaps at 320x240 resolution and resizes it. And the quality suffers badly. :frowning: The software that came with the cam takes good pics at higher resolutions but it does not allow timed snapshots. :frowning:
Also, if i want to buy a new webcam from a better comapny, which one will u suggest? i want to take atleast 800x600 resolution pics or higher with it and atleast 640x480 resolution video recording at 30 fps. which one shoudl i buy? :slight_smile:
