Hi frnds,
its been a while since i posted here cos my pc had been alrite till yesterday..smthg strange is happening..whenever i turn on my pc ..i get the welcome screen and my wallpaper is displayed but i don see my desktop items nor d taskbar .nothing .. no command works excpet for ctrl+alt +del..den i wait for like 20 minutes but the desktop doesnt load..so i logged off and logged in again wid the same user(admin)..but dis time evrything was alrite…
i turn on the pc and again have to log off and log in to view my desktop..:@
You did not mention the OS. I’m assuming its xp pro. I doubt its a trojan. Its a rare occurrence the system process takes a long time to load or doesn’t load at all.
Try disabling a few startup items. Disable services like system restore and indexing.
If the situation does not improve..
Your HDD is on its last legs and hence every now and then you face a slowdown.
i’ve had d same number of startup items before also and my pc is around 7 months old..so ders no questions of my hdd gettin spoilt..its really weird ..my os is xp sp 2..1 gb ram
but der was dis one file dat couldnt be deleted ..it kept sayin’error deletin entry:specifie source does nit exist as installed service.’
and even my startup is real slow man..it too around 30 sec or less wen i first bought d pc but now it takes around 4 min..i tried usin a number of programs to speed up startup but didnt help,hope ur program helps..
d problems seems 2 exist still :@ ..ive restarted and d sam thing happens..d desktop doesnt show up for ever🤔 ..i have 2 logoff and log in so dat my dektop is visible and interactable :@
w8in for ur suggestions (no reformattin suggestion:no: )
mate, i tried doin what u told me but smthg weird happened..from the welcome screen it directly took me into admin account instead of me choosing which account i wanted to log into.. i created guest ccount and i that screen wasnt even shown( i mean d screen wer u choose between users)..it directly logged in as admin..
man i have lot of importnat stuff on dis pc mate and my norton 2007 picked upa trojan dat im not able 2 remove..
im goin offf 2 college now ..plzz think abt dis and give me suggestions…
waitin for ur replies
it will read write to ntfs partitions , has antivirus on it too.
so first back up all ur data , then run antivurs .
now ur data safe , u can choose to repair installation or start over by formating hd.
from next time do these.
keep windows fully updated.
keep drivers fully updated.
keep antivirus fully updated and running(antivir/avg)
keep a different firewall (zone alarm / comodo)
keep a signature based antispyware. it will also run in background , keep it fully updated(spyware terminator)
keep hips(signature based is not enough) based antispyware, i recommend threatfire/defence+ in comodo
use only firefox/thunderbird and not ie/outlook
my advice would be take either of these antivir/avg
then have comodo firewall
it has hips built in(defence+)
man i have to warn u that comodo is not for noobs. join its forums , read about it as it is a very highly complex and configurable piece of software. it even puts commercial solutions to shame(norton internet security)
but once u get a hold of comodo , ur windows will be as rock solid as it can be
or better try moving to ubuntu all togather and stop living in constant fear
Hijackthis shows various dlls and exes that are installed in the computer. you get suspicious about any, just search that exe/dll in the net and you can find if that thing is legit or not. you will find cleaning procedures for almost all the types of viruses, be sure to download the process explorer from here. Process Explorer
using hijackthis, internet and process explorer; you can clean up almost any type of virus.
