XBOX360 VGA HDAV Cable
I am getting a Dell E248WFP and a VGA HDAV Cable for my XBOX360. Are They fully compatible?
How much are you picking up the cable for?
I am buying the original cable. Don’t know the exact price, I think it is 1,890.
If your monitor has a VGA output it will work. My Viewsonic 1932 VX has DVI and VGA and I have the PC into the DVI port and the VGA for the 360 with the official cable. It works fine at just about every resolution the console offers. Looks lovely too.
My monitor has VGA(for X360) and DVI(for PC), the resolution is 1920x1200.
Enjoy your Xbox then! :smiley:
Thank You and same to you.
Hey there as i told u, it will work… And also i think that paying 1.8k for the OG cable makes no sense for me. I would rather buy the 350rs cable. Why people face ghosting with this cable was this cable were not shielded before.
I cannot confirm that there won’t be any ghosting problem with the cheap cable. But i won’t mind giving it a try before putting 1.8k on the cable…
Its Just Me, U might have a different POV …
I Don’t Have any problem spending 1.8k for cable so I will get the original cable.
it will work. i am using it currently on the same lcd. what i have noticed is that it works on 1080i & not 1080p for some reason. i am sure as i can notice many jagged edges etc when on 1080i, so its definitly not progressive. where as if u try 720p it looks better as there are no jagged edges & everything is smooth.
also the cable costs around 1450/1500 & not 1800. this is the original cable i am talking about.
^^ Good then I will save some money and even get the original cable. I’ve seen the prices on xbox india website, maybe they have not updated it.
hi,
cost of:-
Xbox360 Component HD AV Cable - Rs 1890/-
Xbox360 VGA HD AV Cable - Rs 1685/-
^^Thanks For the prices
Take a look the price on website.
XBOX360 VGA HD AV Cable
Hi I bought this cable. It comes with a female- female pin (hard to find) and a audio converter which I use. So all in all, of you want less hassles get the official cable. Just my 2 cents
^Yes I am going to get original Cable.
Damnit! Anyone know where to get the original cable in Bangalore?
You can get the original cable from any Planet M there.
Most places here don’t have it. At least, I have yet to see one. I’ll keep trying though.
Its not been released officaily in India AFAIK. Planet M (Delhi) do stock it though. Its where I got mine. And BF1983 is right anyone planning to buy one spend that extra little bit of cash and get the official one for reasons mentioned.
You getting a 360 Nish??
okay i’m not advertising here.. jus helping out that guy..
all games accessories and consoles are available at Consoul.
located on church street, opp empire inside java city.
XBL Gt : iconsoul3
