The NV5 R2 doesnt fit the 6600 GT AGP , actually no artic cooling product does , reason being , the AGP 6600 GT has a very unique design . It has the PCIexpress to AGP Rialto bridge , which makes it impossible for the NV series to be mounted . The NV6 R2 is for the 6600 GT PCIexpress only , that is if u mistook it for the AGP version too .
So , there are only 2 products for the AGP 6600 GT , and some silent designs , but since we are looking at uber cooling stuff , les consider only the fanned coolers .
Zalman VF700-Cu
Some lesser known brand available in the US , cheaper than the Zalman ,dont remember the name . jus google and check .
Both the coolers work pretty effectively , many people have used the Zalman pretty effectively . U can read the reviews on the internet .
So by now u wud have set ur eyes on the Zalman VF700-Cu , pretty much i guess
SO where do u source it from ?? called Mediatech , the official disti’s of Zalman ? … " Sir we dont stock Zalman cooling devices " … can u specially order one ? …" No sir "
DAMN !!
Well , herez the solution and i guess ur pretty much in time
, and yea BTW’s i have a gigabyte 6600 GT AGP , if ur wondering where am in gettin all this from …hehe
back to the topic , ’ funkymonkey ’ , a beloved member of TE is ordering stuff from www.coolpc.com.au , hez kind enuff to use his credit card for all the members of TE , here is the link to that thread for ur convinience : http://www.techenclave.com/forums/showthread.php?t=4022
Here is the product link : http://www.coolpc.com.au/catalog/product_info.php?products_id=771
Alternatively u cud try this too : http://www.coolpc.com.au/catalog/product_info.php?products_id=621 , though am not pretty sure if it wud make a substantial difference , plus it depends on ur case physics too
( the cabling , airflow and ventilation )
funky is taking the final requests on the 9th , so be sure to place it before that , u can trust him , I vouch for him and so wud many other TE members .
To give u a lil information for ur convinience ( Read this strictly after u have read funky’s thread on mass order ) :
The Zalman VF700-Cu : 300 gms shipping weight
If 2kgs ordered : shipping approximately costs 47 rupees per 100 gms
If 3 Kgs ordered : shipping approximately costs 38 rupees per 100 gms
Plus custom duties which wud be at a max 10% . pretty nominal .
