Best Cooler for E8400 Ocking.
Hey guys..
My E8400 is OCk’d to 3.6 with stock cooler…well with stock cooler my proc is showing 47* in Everest and in Real Temp Core 1 # 43* and Core 2 # 45*C. These are my idle temps :flushed_face:
Already applied MX2 TC..
2ndly NO TRUE 120 in the market…can get TRU 90i..but reviews say Hyper 212 is better or rather as same as TRUE 120 and other is the Zalman 9500..
BTW i keep my system 24/7 for dloading and gaming and lil bit of OCking..Not a OCking FAN..wont be 3.0 to 5ghz
[B]Which cooler to go for?
  • TRU 90i
  • TRUE 120 (N/A)
  • CoolerMaster Hyper 212
  • Zalman 9500[/B]
Also Core 1 = 43* and Core 2 = 46* @ 3.6G with stock cooling decent? or something wrong?
Everest shows (using latest version).. Core 1 56* and Core 2 55* and cpu @ 46*..
…Thanks in advance
PS: Sorry if this was supposed to be under Overclocking section..mods kindly move the topic to Overclock.
get CM hyper 6+ – Rs 3K
Kick ass cooler after True 120..:slight_smile:
Why not go for TRUE 120 then…??? :stuck_out_tongue:
umm, i would suggest the Xigmatek S1283 or the Sunbeam CR-CCTF 120mm “Core Contact Freezer”
Gannu has the Xigmatek, he’ll be able to provide you the feedback.
How much for both of them.. ?? approx idea??
Xigmatek S1283 … gannu, funky and one more in TE have it… slightly better than a tru…get it via KMD route …
Comes with its own fan
here is a review…X-bit labs - Thermalright SI-128 and XIGMATEK HDT-S1283 CPU Coolers: 8mm of Efficiency
PS :Hope no hard feelings from the Brand launch thread :slight_smile:
:slight_smile: no issues from other threads…
anyways… can u provide approx quote?? is it within 2.5k ?
KMD quoted me 2.4k for the same with out the retention kit.
You said, TRUE 120 isn’t available. Thatz why i recon that CM..:slight_smile:
Ok.. is it necessary to buy retention kit? Wht is it exactly? the platform for installing it or something.. ?? 2ndly..you guys sure Xigmatek is better than TRUE 120 ?? never heard of Xigmatek b4 :stuck_out_tongue:
Which one is better - Xigmatek S1283 or Cooler Master Hyper 6+ ??
TRUE / Xigmatek and then CM Hyper 6+…and if am not wrong Hyper 6+ is now old as well..
Xigmatek has a 1 degree edge over tru…chk the xbit review :unamused_face:…and u don’t need extra fans with it…
Xigmatek vs. TRUE vs. CM Hyper 212.. ??? which one to go for?
xigmatek…
cheaper+better
By default, the Xigmatek comes with plastic push pins like the stock cooler for retaining the HSF on the motherboard. But these are hell to use and also many times do not ensure proper contact with the processor surface thus decreasing their efficiency.
In order to ensure proper contact and also support the huge third party coolers like TRUE 120, a bolt through retention kit is used. This involves using a metal back plate and fixing the h HSF properly with screws. If you want you can buy this kit separately. Xigmatek has its own kit, but you can also buy and use the Thermalright kit that’s intended to be used with the TRUE or some of their other Heat sinks.
As for which is better, the Xigmatek is marginally better than the TRUE120, weighs significantly less and also cheaper at the same time including a high CFM 120mm fan in the bundle.
ok..
btw.. also did some r & d on its default retention kit..seems to be pain in ass like intel fans..i dont want that crap..
Btw.. any idea approx..how much the kit cost around? for TRUE 120 retention and Xigmatec Retention Kit?
and BTW.. will this fit w/o any issues in CM 690 with 2 x 120mm fans at the top?
Cooler Master Hyper 212 is **2k **all inclusive in Nehru Place, Delhi. @ this price, its best bang for buck if U have spacious cabby.
As i said.. i’ve got CM 690 with 2 x 120mm Fans @ the Top.
no issues, vNerd is using H212 and CM690 + Top 2 120MM combo
Here @ vertical mounting -
http://img155.imageshack.us/img155/2249/sideof2em5.jpg
Horizontal mounted -
http://img155.imageshack.us/img155/3840/cmim7.jpg
:slight_smile:
